09-25-2014, 11:05 AM | #1 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
| How to convert Ascender trans to a Two Speed
Here is the list of parts required to convert your Ascender transmission to a 2 Speed and a link to the instruction manual below. Note that you will need a "Mini" servo to operate the shifting, at least a 3 channel receiver and a transmitter with a 3rd channel/button with "2 position switch" Parts needed: VTR332009 Transmission Metal Gear Set: Twin Hammers OR VTR332000 Transmission Molded Gear Set: Twin Hammers VTR232008 High- & Low-Speed Gear Set: Twin Hammers (Top shaft gears) VTR232009 Transmission Shift Fork & Shaft: Twin Hammers VTR232007 Transmission Shift Linkage Set: Twin Hammers (the picture is old on our site, the current parts should have a spring and 2 piece arm that acts as a servo saver) VTR232017 Transmission Shaft Set: Twin Hammers (sorry guy, you only need the small aluminum spacer and we only offer it in this set) VTR237003 4mm x 8mm x 3mm Ball Bearing x 1 (You'll need 2 bearings) VTR237004 5mm x 10mm x 4mm Ball Bearing x 2 (you'll need 4 bearings) VTR236131 E-Clip 3mm x 1 (You'll need 2 e clips) VTR236013 M2.5 Nylock Nut x 1 (You'll need 1 Nut) VTR235108 M3 x 12mm Button Head Screw x 1 (You'll need 2 screws) LOSA6356 5&6mm Shim set 5x7x.02mm shim x 1 This is the only way we sell the shims by themselves. Link to Twin Hammers Kit Instruction manual You will use the following steps: A-2 thru A-6 (Disregard the outer standoff mount in A-6) A-12 and A-13 One tip is to make sure the shifting shaft that slides in and out of the transmission case has a smooth finish to it. For the most part, our production parts have a smooth finish but I've seen some with a slightly rougher texture and this can cause the shaft to stick in the transmission case, making it harder to shift. I always polish it to make sure it's smooth. Rich Last edited by Rich Trujillo; 08-31-2015 at 04:40 PM. |
09-25-2014, 11:38 AM | #2 |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
| Re: How to convert Ascender trans to a Two Speed
As far as I can tell you also need 4 5x10x4 bearings for the extra gears on the lower shaft, 2 4x8 bearings for the extra gear on the middle shaft, and maybe a couple e-clips for the shift fork.
09-25-2014, 12:23 PM | #3 |
| Re: How to convert Ascender trans to a Two Speed |
09-25-2014, 08:05 PM | #4 |
Rock Crawler Join Date: Jul 2005 Location: MD
Would an entire twin hammers transmission contain all these parts? I have a spare sitting on the shelf.
09-25-2014, 09:53 PM | #5 |
09-28-2014, 11:10 PM | #6 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
hey Rich, will a standard servo fit the mounts for the 2speed tranny? or should i get a mini servo? i am purchasing all the parts that makes the 2-speed as listed soon, already in the cart. |
09-29-2014, 10:30 AM | #7 |
| Re: How to convert Ascender trans to a Two Speed A standard servo will not fit but I have seen others modifying it to work. Check the Twin Hammers forum and you should be able to find the info you need.
09-29-2014, 01:52 PM | #8 |
Appreciate it! |
10-02-2014, 11:51 AM | #9 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
Will these parts be offered in a kit any time soon? Mainly thinking about new drivers/builders possibly getting into their first kit and not so savvy with cross referencing parts from other trucks.
10-02-2014, 01:41 PM | #10 | |
| Re: How to convert Ascender trans to a Two Speed Quote:
Thanks, Rich | |
10-10-2014, 05:56 PM | #11 |
Newbie Join Date: Dec 2012 Location: latonia
Hey rich I know this is off subject but im trying to find out the length of the ascender shocks from eye to eye?? I plan to get a kit as soon as im able but am considering these shocks for my 2 scx10s that I currently own being I have read a few comments stating how smootn these stock shocks are..currently I have my stock plastic scx shocks setup at 95mmmeye to eye via longer rod ends..also are there softer springs available?? And what springs come stock soft medium or hard.
10-17-2014, 05:16 PM | #12 |
Rock Stacker Join Date: Feb 2011 Location: KS
Bah, this needs to be put together as a kit. Or, just offered straight up in the kit. I love my 2-speed in my TF2, and someday, hope to love it in my Ascender.....
10-18-2014, 12:09 AM | #13 |
10-18-2014, 12:24 AM | #14 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
I took 2 speed off no way to get the epa set with a mini it fried 2 I gave up Sent from my iPhone using Tapatalk |
10-18-2014, 10:37 AM | #15 |
Interesting. I have a mini Futaba S3016 in my Twin Hammers (same two speed) and didn't have any issues setting the EPA's. Its still kicking even without a servo saver. Does your radio have a 2 position 3rd channel, or 3 position? Whats a rough idea of the cost of all the parts required to do the 2 speed conversion, minus the servo? |
10-18-2014, 10:43 AM | #16 |
I use a dx3c its 3p switch I've had a tf2 no probs had a ax2 in a dingo no prob had digs no prob just this one and I spent close to 80 in parts to convert Sent from my iPhone using Tapatalk |
10-18-2014, 11:04 AM | #17 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
buy a twin hammer tranny someone is parting out?? saw a few on ebay
11-03-2014, 04:20 PM | #18 |
Is the shift fork supposed to come with c-clips or do those come separate as well? I was all excited as I finally had all the parts this thread said I needed, but the shift fork bag only had the rod and fork in it.... no c-clips. Where can I get those? Or what size are they? There is also no vtr236013 m2.5 nut for the shifter in the parts listed.
11-03-2014, 05:39 PM | #19 |
the clips come separately, i used spares from old shock assemblies. and here i am not being of any help as i am not sure what size they are. :(
11-03-2014, 06:27 PM | #20 |
| Re: How to convert Ascender trans to a Two Speed Yup, just got done doing the same. :( Had to tear apart a perfectly good Slash shock for the e-clips. Where did you get a m2.5 nut for the shift rod?
How to convert Ascender trans to a Two Speed - Similar Threads | ||||
Which 2 speed trans to get???? help! | dwblue00 | Axial SCX-10 | 10 | 08-23-2013 12:37 AM |
2 speed trans | DIZZE004 | General Scale Talk | 0 | 11-07-2010 12:27 PM |
What 2 speed trans to use? | McCready | 2.2 Scale Rigs | 2 | 08-13-2010 07:13 AM |
Scale Speed... how do you convert it??? | norbyx | Chit Chat | 11 | 06-16-2010 10:39 AM |
