06-15-2018, 09:59 AM | #21 | |
| Re: The Sheriff of Ulaanbaatar Quote:
https://www.prolineracing.com/insert...am-inserts.asp The beadlock mounting is not fun, but gets easier the more you do it. | |
06-15-2018, 10:16 AM | #22 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Sent from my ZTE A2017U using Tapatalk | |
06-23-2018, 05:08 AM | #23 |
Quarry Creeper Join Date: Nov 2017 Location: Ulaanbaatar
Update: The Sheriff of UB (Ulaanbaatar) is nearly ready to keep the peace: 1. When the smallest size available at the local print shop is a square meter [IMG][/IMG] 2. I got loads of 4 variations of the UB City logo. This gold one will likely go on the hood of The Sheriiff [IMG][/IMG] 3. I'm pleased overall, but these Gmade steel beadlocks do not want to hold the stock tires. I think I read that the RC4WD Proline rings will help? Also, I may paint the wheels white when I take them off to remount the tires....AGAIN [IMG][/IMG] As always, thanks for stopping by, MP |
06-23-2018, 08:32 AM | #24 |
Looking good. I really like the paint job. Sent from my ZTE A2017U using Tapatalk |
06-24-2018, 06:28 PM | #25 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
When it comes to mounting the stock tires on the Gmade Steelies, do not worry about setting the front and back into the bead groove. What you need to do is make sure you get the beads properly seated over the edge of the inner ring then you need to just set the front and rear on the tire as if they were just hub caps. The beads are super thick and very difficult to mount on all brands of beadlocks. I tried half a dozen times with no success. That’s how I have mounted mine and have never had a bead pull out, I have been using them for a year that way, give it a shot. Hope that method makes sense ? |
06-25-2018, 07:46 AM | #26 | |
I'm not sure I follow, but I'll read it again once I have them apart....again. Do yours appear to be seated properly, or does the bead peek out? Cheers, MP | |
06-25-2018, 08:25 PM | #27 |
| Re: The Sheriff of Ulaanbaatar Don’t try to mount then in the traditional manner, basically you just set the front and rear on the tire. Do not worry about trying to get the front and rear pulled into the bead groove, the beads are too thick and will just pop out. You just set them on the tire and install the screws and tighten. Hope that helps out.
07-04-2018, 11:06 AM | #28 |
UPDATE: [IMG][/IMG] After the maiden run of the Sheriff, I am very pleased. I was planning to leave things as is for now, except for a police light bar that is taking a long time to get to Mongolia...BUT [IMG][/IMG] The AWESOME guys from HWY 1 Rc sent me this Hobbywing XR10 Juststock ESC/21.5 brushless combo. Would you guys recommend this over the brushed HW1080/Tekin 35T set up? If so, how to I set this up for trailing/crawling? It seems to be for racing?? Thanks for stopping by, MP |
07-04-2018, 01:23 PM | #29 |
That brushless setup is for racing or go fast stuff, I would leave the brushed combo you have in there. |
07-05-2018, 12:45 AM | #30 | |
Cheers, MP | |
07-05-2018, 08:22 AM | #31 |
You’re welcome Pete. It is sensored so might be ok, just hard to beat the brushed setup you’re running. |
08-05-2018, 10:18 AM | #32 |
Great time up on the mountain with The Sheriff today. Definitely happy with the 1080/Tekin HD 35t combo. [IMG][/IMG] Thanks for stopping by, MP |
08-05-2018, 10:40 PM | #33 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Hey Pete! Caught you on Facebook earlier. Looking good! Chris |
08-06-2018, 07:27 AM | #34 |
| Re: The Sheriff of Ulaanbaatar Hi Chris, Thanks! I've not been on the Ascender forum too much lately cause I'm like a crackhead about my next build, an Axial SMT10-based SAMT It is all I think about, even when I'm running my other bashers and trail trucks. Cheers, MP |
The Sheriff of Ulaanbaatar - Similar Threads | ||||
Sheriff"s Blazer | lappdogg | 1.9 Scale Rigs | 29 | 03-23-2016 04:47 AM |
1.9 harris county sheriff chevy crew cab... | ctrwannabe | 1.9 Scale Rigs | 15 | 08-09-2009 09:26 AM |
