Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Broken pin of rear pinion driveshaft, now how to disassemble???
Old 10-02-2018, 03:21 PM   #1
Default Broken pin of rear pinion driveshaft, now how to disassemble???
Ok I understand this sounds stupid, but really I'm having quite a headache on how to remove the rear pinion from axle to change the damned pin. Can't find a safe way to grab the pinion gear, nor can grab the recessed cvd from outside. If i remember correctly the pinion bolt has some loctite too. I'm stuck!
rockspider is offline   Reply With Quote
Old 10-02-2018, 03:29 PM   #2
Default Re: Broken pin of rear pinion driveshaft, now how to disassemble???
It can be a bugger to get that out. Usually a little heat will loosen it up. Heating it can be hard without melting the plastic but it can be done.
Sent from my ZTE A2017U using Tapatalk
mgputer is offline   Reply With Quote
Old 10-02-2018, 03:34 PM   #3
For heating I can use the solder iron, done that before on other models.
But the main problem is having a grab on the pinion/cvd to loosen the screw. Can't grab it at all without damaging the pinion gear...
Old 10-02-2018, 04:09 PM   #4
If the drive shaft is still attached you can hold that.
If you just have the cup then what I do is put an Allen wrench or pin of some sort through one of the holes. Then I use a pair of small pliers and put one jaw in the cup and the other on the axle and squeeze it enough to hold it from spinning when the Allen or pin touches the end of the pliers. This usually works.
Old 10-02-2018, 05:12 PM   #5
When I have to remove these (without being broken) I use some shock shaft pliers to hold onto the stub on the outside. And now that I think about it these dont use a pin at all, see picture here https://www.rpphobby.com/product_p/vtr232072.htm
but maybe the flat spots have rounded over, either way you should be able to grab onto the stub that sticks out of the pumpkin and loosen the screw holding the pinion from the inside.
EDIT: so what is broken the pin in the driveshaft? or is the pinion spinning on its shaft?
Oh and something that might be helpful in the future is the drive shaft adapters that GCM racing and Vanquish make that allow you to use a standard driveshaft, they connect with the typical pin/set screw https://www.rpphobby.com/product_p/vps08200.htm
HumboldtEF is offline   Reply With Quote
Old 10-03-2018, 01:13 AM   #6
I made a tool out of piano wire from the hooby store, it’s the same wire I use to make my own pins when they wear out.
Give me a minute to find what page it is on my thread....got a couple of pics of it.
Yeti.stealth is offline   Reply With Quote
Old 10-03-2018, 01:17 AM   #7
Go to post number 185 in the link below to see my solution to your problem!
Yeti.Stealths Ascenders
Old 10-03-2018, 03:44 PM   #8
Very clever solution! Have to find suitable sized wire and give a try, thanks man!
Old 10-03-2018, 06:31 PM   #9
That is a great solution Yeti.Stealth! If you have a set of snap ring pliers that can be reversed that might do the trick too.
Broken pin of rear pinion driveshaft, now how to disassemble??? - Similar Threads
Broken pin in rear axle driveshaft cup. krazykrawler Vaterra Ascender 3 01-06-2016 08:17 PM
Broken CV Pin - ax30464 SCX10Dingo Axial SCX-10 6 07-07-2013 10:32 AM
Broken CVD pin Rocknroddez Venom Creeper 5 11-06-2012 06:40 PM
Broken rear driveshaft losikid Team Losi Comp Crawler 1 04-09-2010 08:38 PM
broken axle pin dirtridr89 General Crawlers 7 05-06-2006 07:07 PM
