01-08-2019, 07:28 PM | #1 |
Newbie Join Date: Jul 2013 Location: Skook
| HKSkook's Vattera 254mm Tamiya Bronco build.
Hello guys a while back I tried to research what Breadbox Bronco build I wanted to do. I'm trying to make it as scale to my Traxxas Bronco as I could. With little info on the Jconcepts Bronco I just felt it was too long. I decided to go with the Tamiya body. To use it on the Vattera I would need to get the wheelbase down to 254. So far I've cut the frame (both ends). I have it mocked up. I ordered gmade 54mm links. Using the wheel base guide Vattera provides going with 54mm links on bottom should get me within 2mm. I'm looking for any info on shocks and wheels I can find. Stock is 108mm I'm guessing maybe 90mm will look right with the 1.55 wheels I want to use. I will post pics as I get stuff in and get closer to completion. Any insight would be appreciated. Sent from my SM-G950U using Tapatalk |
01-08-2019, 07:54 PM | #2 |
| Re: HKSkook's 254mm Tamiya Bronco build.
Awesome idea! Haven't seen a short TRX-4 yet. Nice start.
01-08-2019, 07:57 PM | #3 |
Newbie Join Date: Mar 2018 Location: US
The 1/12 ECX Barrage Gen 2 would be a great fit for that Bronco body. Sent from my Nexus 7 using Tapatalk |
01-08-2019, 07:59 PM | #4 |
| Re: HKSkook's 254mm Tamiya Bronco build. |
01-09-2019, 06:30 AM | #5 |
01-09-2019, 06:36 AM | #6 |
01-09-2019, 10:54 AM | #7 |
| Re: HKSkook's Vattera 254mm Tamiya Bronco build.
Completely agree on the Bronco body, Tamiya does it best and most scale short of a hardbody. Great body choice, welcome to RCC and looking forward to your build. SVT923 has a nice build using this shell too. The Seemingly Eternal Evolution of SVT's Ascender |
01-09-2019, 12:27 PM | #8 |
01-10-2019, 07:28 AM | #9 |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: HKSkook's 254mm Tamiya Bronco build. Check out post #17. https://r.tapatalk.com/shareLink?url...0&share_type=t Sent from my Pixel 2 XL using Tapatalk |
01-11-2019, 06:07 PM | #10 |
Ok got the Gmade 54mm links in. They work perfect and will only need to make 1 custom one for the front top link. Rear shock angle is leaving a bit. However I think I will roll with it. Had to cut more off frame. Wheelbase is looking perfect. Sent from my SM-G950U using Tapatalk |
01-12-2019, 08:18 PM | #11 |
Just a quick mock up with tires. Driveshafts have been cut. Everything went smooth. Need to order back body mount. Sent from my SM-G950U using Tapatalk |
01-17-2019, 07:00 PM | #12 |
Little update. Body is mounted ready for paint. Screwed up a little in rear end but shouldnt be a issue. Haven't painted a 2 color scheme in a while so hoping I dont screw it up too bad. Tomorrow is more body trimming and paint prep. Sent from my SM-G950U using Tapatalk |
01-18-2019, 08:13 AM | #13 |
Very cool.... I was thinking some less offset wheels would help tuck the tires, but there's not much room next to the steering knuckles. Not sure you could pull the tires in much more.
01-18-2019, 08:18 AM | #14 |
I assume the wheels are 1.9s. Short course wheels would probably clear the knuckles. Just a thought.
01-18-2019, 01:05 PM | #15 |
| Re: HKSkook's Vattera 254mm Tamiya Bronco build. |
02-06-2019, 06:17 PM | #16 |
Just a quick update. Wheels and tires are in! Haven't had much time to work on it. What are the smallest RC4wd spacers to reduce back spacing? Sent from my SM-G950U using Tapatalk |
02-16-2019, 05:43 PM | #17 |
Getting there Sent from my SM-G950U using Tapatalk |
02-20-2019, 10:46 AM | #18 | |
| Re: HKSkook's Vattera 254mm Tamiya Bronco build. Quote:
https://store.rc4wd.com/OEM-Steel-19...es_p_1249.html | |
02-20-2019, 11:48 AM | #19 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
yeah narrow the axles for sure. and these wheel adapters are exactly what you need... eliminates the hex entirely to get the wheel right against the pin... if they will clear your knuckle though is the question... https://store.rc4wd.com/Reduced-Offs...ls_p_5411.html |
02-20-2019, 02:52 PM | #20 |
OOps I linked adapters that I use for 1.9s, Shinchu has the nice and narrowest setup there for 1.55s. |
HKSkook's Vattera 254mm Tamiya Bronco build. - Similar Threads | ||||
project "baloo", a tamiya bronco build | sods | 1.9 Scale Rigs | 26 | 08-02-2015 04:35 PM |
Tamiya Bronco Kit Build; 1st Build | Boxcarcustoms | 1.9 Scale Rigs | 2 | 07-29-2013 07:37 PM |
New Tamiya Bronco scale build | drtrydr2000 | 1.9 Scale Rigs | 37 | 03-06-2010 06:41 AM |
Reign K2-5 Tamiya Bronco build | Just Zach | 1.9 Scale Rigs | 26 | 09-24-2009 09:07 AM |
