03-01-2019, 09:54 AM | #21 |
| Re: Ascender parts
Thanks for starting a thread, I was imagining the servo mount piece (for WB4) but didn't recall the ESC mount! Nice start to your basement course, enjoy and keep us updated! |
03-01-2019, 11:02 AM | #22 |
Rock Stacker Join Date: Jan 2019 Location: Mcleansboro
| Re: Ascender parts
There is more to the basement coarse will post more pics this evening Sent from my SM-S367VL using Tapatalk |
03-01-2019, 11:03 AM | #23 |
| Re: Ascender parts
Got an incline test to Sent from my SM-S367VL using Tapatalk |
03-01-2019, 12:57 PM | #24 |
| Re: Ascender parts
Incline test not sure on degree the coarse from beginning Sent from my SM-S367VL using Tapatalk |
03-05-2019, 01:28 PM | #25 |
| Re: Ascender parts
Was going to upgrade servo but found that servo screw head is stripped out from factory what do I do Sent from my SM-S367VL using Tapatalk |
03-05-2019, 01:36 PM | #26 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Ascender parts
Can you drill the head off the screw? If you are changing the servo just do that. Or get a horn for the new servo.
03-05-2019, 01:39 PM | #27 |
| Re: Ascender parts
I got a new horn but wanted to use servo on my e10. Didn't know if I would be able to save servo Sent from my SM-S367VL using Tapatalk |
03-05-2019, 01:39 PM | #28 |
Newbie Join Date: Feb 2019 Location: Fresno
| Re: Ascender parts
How bad is it stripped? Sent from my SM-G955U using Tapatalk |
03-05-2019, 01:41 PM | #29 |
| Re: Ascender parts
Bad enough I can't get any Allen key to grab at all looks pretty round in the hole Sent from my SM-S367VL using Tapatalk |
03-05-2019, 01:43 PM | #30 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender parts
Honestly I would just order a new one. You can get a ds3218 on Amazon under$20 and it's a great servo and comes with an aluminum servo horn. Sent from my Vivo XI+ using Tapatalk |
03-05-2019, 01:44 PM | #31 |
| Re: Ascender parts
Ehh. I know using quality Allen's make a difference, but if it's already that bad it may be to far gone. Maybe a left handed drill bit would back it out. Give Horizon a call. They've sent me out replacement parts. Not sure if they'd send you a servo tho Sent from my SM-G955U using Tapatalk |
03-05-2019, 01:46 PM | #32 |
| Re: Ascender parts
Ok thanks will see what I can come up with Sent from my SM-S367VL using Tapatalk |
03-05-2019, 01:57 PM | #33 |
| Re: Ascender parts
If you can get the head off the screw, then maybe pull the horn off and try locking pliers on the stub of the screw.
03-06-2019, 03:54 PM | #34 |
| Re: Ascender parts
What's the best way to remove glue on tires and save the plastic rims Sent from my SM-S367VL using Tapatalk |
03-06-2019, 04:30 PM | #35 | |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
| Re: Ascender parts Quote:
You need to use heat to melt the glue. You can bake in the oven at a low temperature, or even use a halogen floodlight bulb. Sent from my iPhone using Tapatalk | |
03-06-2019, 04:41 PM | #36 |
| Re: Ascender parts
I've been told to boil them but will it ruin the pan Sent from my SM-S367VL using Tapatalk |
03-06-2019, 05:00 PM | #37 |
| Re: Ascender parts
I've heard the baking works best. Not sure how plastic wheels will hold up to it tho Sent from my SM-G955U using Tapatalk |
03-06-2019, 06:41 PM | #38 |
| Re: Ascender parts
Boiling does not ruin the pan. The oven works but you have to be very careful with the temperature or you can ruin them. I personally boil them. Sent from my Vivo XI+ using Tapatalk |
03-06-2019, 06:56 PM | #39 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: Ascender parts
I use a cheap heat gun from Harbor Freight, set on low I go around the tire for 30 seconds, stop and see if its starting to loosen up, then I keep going around the rim for 15 second intervals til it completely loosens up then flip the wheel over and repeat, works great for me. Always keep the gun moving never stay in one spot. Rims and tires are reusable with this process.
03-07-2019, 10:05 AM | #40 | ||||
Ascender parts - Similar Threads | ||||
3D Printed Ascender Parts | robertjpjr | Vaterra Ascender | 7 | 12-27-2017 09:39 PM |
