03-28-2019, 04:59 PM | #61 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender parts
Looks good. Sent from my Vivo XI+ using Tapatalk |
03-31-2019, 06:28 PM | #62 |
Rock Stacker Join Date: Jan 2019 Location: Mcleansboro
| Re: Ascender parts
Do ya'll think a guy can bore out a bearing hole 1 millameter for a bigger bearing I got 5 10 4 hole but on hand I have 5 11 4 bearings Sent from my SM-S367VL using Tapatalk |
03-31-2019, 07:35 PM | #63 |
| Re: Ascender parts
I wouldn't recommend it unless you have a good way to bore it accurately. Sent from my Vivo XI+ using Tapatalk |
03-31-2019, 07:40 PM | #64 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Ascender parts
Anything less than precision in a bearing is problematic. Lights are a nice touch. WHatya use for rear buckets? |
03-31-2019, 08:50 PM | #65 |
| Re: Ascender parts
On the rear I only used the holes that where in the cross member for now Sent from my SM-S367VL using Tapatalk |
03-31-2019, 09:06 PM | #66 |
| Re: Ascender parts |
03-31-2019, 09:24 PM | #67 |
| Re: Ascender parts Sent from my SM-S367VL using Tapatalk |
04-06-2019, 09:51 PM | #68 |
04-10-2019, 04:51 PM | #69 |
| Re: Ascender parts
How many of y'all think or take the k10 in deep water? Saying deep as in 6 or 7 inches. Mine is complete stock yet say for a new servo that is waterpeoof. Well and light kit. Sent from my SM-S367VL using Tapatalk |
04-10-2019, 05:59 PM | #70 |
| Re: Ascender parts
I splash in it but never submerged. Wouldnt intentionally submerge electronics or a lipo myself, but guys do
04-10-2019, 06:07 PM | #71 |
| Re: Ascender parts
The receiver box is only splash proof. If you submurge it you will fry the receiver. Sent from my Vivo XI+ using Tapatalk |
04-10-2019, 06:50 PM | #72 |
| Re: Ascender parts
So what you saying is that a couple inches is not terrible. What did you do about the breather holes in stock rims? Sent from my SM-S367VL using Tapatalk |
04-10-2019, 07:08 PM | #73 |
| Re: Ascender parts
I never did anything with the tires. I try not to get more than an inch or so. But I usually upgrade my wheels and tires and typically don't have issues because they are not vented. Sent from my Vivo XI+ using Tapatalk |
04-10-2019, 07:14 PM | #74 |
| Re: Ascender parts
Right that's on the to do list is new wheels and possibly a set of pit bulls. Sent from my SM-S367VL using Tapatalk Last edited by Squirral; 04-10-2019 at 07:17 PM. |
04-13-2019, 07:14 AM | #75 | |
Newbie Join Date: Feb 2019 Location: Nashville
| Re: Ascender parts Quote:
My first real crawl/ride with my K10 WB Ascender was pretty hardcore considering it was new & I barely knew how to control it balance wise and whatnot. I mention this because you asked how many of us traverse deeper water; mine flopped on to it's side & rolled down into a 3' deep water erosion ditch we were crawling past , landed on it's roof in about 8" - 10" deep ,running water. It took me 1min to get to where I could grab it without falling in myself. Its motor ,battery ,servos, receiver , ecm , everything had been fully underwater ,while on , for at least 70-90 seconds. I shook it off , cursed , then slowly spun the FWRD then RVRS throttle to "sling" what h2o I could but then kept on driving. These things are water resistant and almost water-proof. I wouldn't dunk it but they can handle some water . I dielectric grease everything , same as my full scale rigs. | |
04-19-2019, 06:59 PM | #76 | |
Sent from my SM-S367VL using Tapatalk | |
04-29-2019, 07:05 PM | #77 |
07-09-2019, 06:25 PM | #78 |
| Re: Ascender parts
Been a bit I been in and out a the fields here but now I get to get back out and play Sent from my SM-S367VL using Tapatalk |
01-07-2020, 08:29 PM | #79 |
| Re: Ascender parts
Has anyone touched on or even had a problem removing the bolt that holds the spare tire on. Mine is acting as if it is over tightened from factory and wants to round in the plastic holder. Sent from my SM-S367VL using Tapatalk |
Ascender parts - Similar Threads | ||||
3D Printed Ascender Parts | robertjpjr | Vaterra Ascender | 7 | 12-27-2017 09:39 PM |
