Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Driveshaft upgrade
Old 03-26-2019, 07:36 AM   #21
Default Re: Driveshaft upgrade
Originally Posted by Browneye View Post
Those look nice. How do the internals compare?
They are very similar to the junfac. The only thing I didn't like is they didn't come with pins for the diff end but the stock fit.
Sent from my Vivo XI+ using Tapatalk
mgputer is offline   Reply With Quote
Old 03-26-2019, 06:55 PM   #22
Originally Posted by mgputer View Post
These are what I use. They work really well and only $32.
https://www.amazon.com/Vaterra-Blaze...s%2C187&sr=8-2
It says on that page that the fronts are longer than rear... Are you sure those specs are accurate? If not I ordered wrong ones
rag6 is offline   Reply With Quote
Old 03-27-2019, 05:35 AM   #23
The listing is wrong. The short one is for the front.
Old 07-21-2019, 11:23 PM   #24
What size Junfac driveshaft did you use on the Ascender k5 ?
Damond is offline   Reply With Quote
Old 07-24-2019, 09:36 PM   #25
I have them on my K-10...
I don't have the size offhand, but give me a few and I will see what I can find....
druz is offline   Reply With Quote
Old 08-07-2019, 10:22 AM   #26
MEOW
Natedog's Avatar
Check the SCX10ii driveshaft specs, they are similar to Ascender, should at least give a starting point. Do you have an LHS with crawler parts in stock?
Driveshaft upgrade - Similar Threads
Rear Driveshaft Upgrade Bicketybam Losi Rock Rey 8 07-27-2019 01:41 PM
Ascender Driveshaft Upgrade YDAZOPEN Vaterra Ascender 4 03-02-2017 06:09 PM
Driveshaft upgrade for AX10? Josh_Br Axial AX-10 Scorpion 26 08-03-2012 08:27 AM
Driveshaft Upgrade Qs Barillms Axial AX-10 Scorpion 14 10-04-2007 10:42 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
