Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: V100 are they the same??
Old 07-16-2019, 07:06 PM   #1
riz
Default V100 are they the same??
Do the V100 cars and trucks use the same chassis?? Are all the car / truck bodies interchangeable ? If I bought a car bodied V100, could I remove the car body and put on a V100 truck body?
riz is offline   Reply With Quote
Old 07-16-2019, 08:41 PM   #2
Default Re: V100 are they the same??
Pretty sure the wheel base are the same for v100 chassis. Might get answer in non-crawler section.
hillbillyrc is offline   Reply With Quote
Old 07-17-2019, 11:05 AM   #3
The v100 is a 11" wb so you have to use WB1 on teh ascender and the wheel arches line up pretty close. The grill is different between the v100 and ascender versions. You can make them work but it takes a little effort.
mgputer is offline   Reply With Quote
Old 07-17-2019, 11:44 AM   #4
quick answer is YES. v100=v100 and as far as i know, wheelbase on that chassis does not adjust without custom work.
Shinchu is offline   Reply With Quote
V100 are they the same?? - Similar Threads
Vatterra v100 going brushless mikemollic Non Crawler RC's 0 11-05-2017 07:13 PM
Vaterra V100 onroad cars Jus Non Crawler RC's 105 03-20-2016 08:21 PM
Vaterra V100 Rally Blaster 75 Rally 1 04-26-2015 04:16 AM
