11-09-2019, 11:57 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
| High gear only
Has anyone did a high gear only from the Twin Hammers gearbox on the Ascender? I swapped to Axial AR44 axles and would like to regear the trans.
11-10-2019, 05:52 AM | #2 |
| Re: High gear only
You can achieve the ratio you need by simply swapping the external pinion and spur. Exactly what you want will depend on your tire size, motor, and 2s or 3s. I'd suggest starting at 23/78 to get in the ballpark. Should give you a final drive of about 51:1, which is a hair slower than stock ascender final drive.
11-10-2019, 02:54 PM | #3 | |
| Re: High gear only Quote:
High gear only - Similar Threads | ||||
Big Gear, Low Thottle vs Little Gear, High Thottle | summerof95 | Electronics | 18 | 02-02-2015 02:23 PM |
high gear ratios | losikid | Team Losi Comp Crawler | 6 | 02-07-2011 04:08 PM |
AX10 shift kit or shifting from Low gear to High gear? | legobrains | Axial AX-10 Scorpion | 19 | 10-27-2007 12:24 AM |
High Gear | redidbull | General Crawlers | 7 | 12-31-2005 07:08 AM |
High/Low Gear ? | Fishmaxx | Traxxas Crawlers | 1 | 02-25-2004 08:37 AM |
