08-14-2020, 06:52 PM | #1 |
Rock Stacker Join Date: Jan 2020 Location: Felton pa
| Starting a new build based on the Ascender chassis and trans
Hey gang need some help figuring out spur gears that will fit the Ascender trans other then the stock one I would like to drop down on tooth count to get the gearing I need this build is getting portals Sent from my iPhone using Tapatalk |
08-14-2020, 09:07 PM | #2 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
| Re: Starting a new build based on the Ascender chassis and trans
The Vaterra twin hammers spur gear is a direct bolt on. It’s 78tooth compared the the ascenders 86 tooth. Not sure if this will get you down enough. Plus you can go plenty bigger on pinion your gain some speed to make up for the portals. Ben |
08-14-2020, 09:25 PM | #3 | |
| Re: Starting a new build based on the Ascender chassis and trans Quote:
Is it true that the scx10 spur will work on these I am trying to find steel gear Sent from my iPhone using Tapatalk | |
08-17-2020, 11:20 PM | #4 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
I dont have any scx10 spurs to try but I did the twin hammers spur and it was perfect for clearing the gcm forward motor kit.
Starting a new build based on the Ascender chassis and trans - Similar Threads | ||||
DMG Thug Chassis based build.... | allanon1965 | 2.2 Scale Rigs | 37 | 05-28-2018 03:13 PM |
My P4 Clod-based chassis build | GraTou | Tamiya TLT Crawlers | 19 | 01-21-2007 05:06 AM |
