Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Twin Hammers
Thread: Badger's Vaterra Twin Hammers 1.9 Rock Racer
Old 02-08-2013, 08:21 AM   #341
Default Re: Badger's Vaterra Twin Hammers 1.9 Rock Racer
I liked the way that the back of the chassi, that has the spare on, flexed away on impact, much better than being rigid and braking.
Thanks Badger to have the patience to reply to all of these questions.
It sure looks like a great RC.
xkill is offline   Reply With Quote
Old 02-08-2013, 09:17 AM   #342
what is the motor on that twinhammers in the video?
theclimber is offline   Reply With Quote
Old 02-08-2013, 09:38 AM   #343
Diggin' the new SCX10 II!
badger's Avatar
Originally Posted by ttv8ra23 View Post
Would it be slower or faster than the standard setup on 3s lipo I'm afraid I don't really understand how turns work.
Your question is a little vague. You can't run 3s on the standard (stock) setup because the ESC does not support 3s.
Check out this thread to read up and learn more about RC electronics.
Definitive ESC, MOTOR, and BATTERY threads - RCC's top tech threads!
Yeah it's impressive. And to think this isn't even the worse it's been through.
The motor is the Tekin ROC 412 3100kv
badger is offline   Reply With Quote
Old 02-08-2013, 10:31 AM   #344
hi badger.
thanks for all the info.
can you maybe upload an unedited version of this vid? it could help me and others understand the speed and handling of this rig.
is it metric hardware?
ebay007 is offline   Reply With Quote
Old 02-08-2013, 10:47 AM   #345
badger's Avatar
Originally Posted by ebay007 View Post
hi badger.
I am working on the full video which will have plenty of full speed shots showing how well it handles.
It's all metric hardware.
Old 02-08-2013, 11:02 AM   #346
I'm like the look of the power it has with that tekin roc motor in there,
Can't wait to see the full speed video
Thanks for all the comment to are answers it is very helpfull
chevotafun is offline   Reply With Quote
Old 02-08-2013, 11:45 AM   #347
So on average the run time is give or take 20 mins depending on driving style? My question in regards to that, is how long does it take to charge the stock battery after died?
I know a little noob question but I've been out of scene for awhile and know nothing about lipos.
CuriousGeorge is offline   Reply With Quote
Old 02-08-2013, 12:16 PM   #348
06 Super National Champ
JasonInAugusta's Avatar
Li-Pos really don't make a difference. Its mAh capacity of the battery and charge rate that determine how long it will take to charge the pack
From the specs...
• Dynamite 2S 7.4V 2000mAh Li-Po Battery
• Dynamite 1.8-AMP AC Li-Po Wall Charger
It'll take about an hour with the included charger. Maybe a bit over depending on how many mAh you used.
With a better Li-Po capable charger you could charge at a higher amp rate (if the battery will support it) and reduce the time. I'm not sure what the C rating for charging is on the included battery. Maybe badger can answer that.
JasonInAugusta is offline   Reply With Quote
Old 02-08-2013, 12:26 PM   #349
Most of the Dynamite packs I have seen are rated for 3C charging. Even at 1C on a good charger it should only take 20-30 minutes to charge 2000mah.
MX304 is offline   Reply With Quote
Old 02-08-2013, 12:40 PM   #350
A 1C charge rate for a 2000mAh pack is 2A.
It will take about an hour for a charger running at 2A to put 2000mAh into a pack.
At 3C (6A charge rate) it will take about 20 minutes to put that same 2000mAh into the battery.
Old 02-08-2013, 04:35 PM   #351
not sure if this has been asked or not but what gearing are you using with the roc motor?
Any chance the spur would be able to be switched to a 32p spur setup? have only been able to find a 22t 48p 5mm bore pinion lol I plan on using my 3300kv pro4. lol
jthellfire911 is offline   Reply With Quote
Old 02-08-2013, 04:41 PM   #352
Amain have a good selection of Robinson 48p 5mm pinions in stock.
Congrats to Randy Slawson 1st finisher 2013 KOH , pity its a live axle rig , there goes a Twammer build of his rig!
northkona is offline   Reply With Quote
Old 02-08-2013, 06:31 PM   #353
so originally i couldn't decide between the twin hammers or the SCX10 jeep wrangler, so i got them both
shoot me a PM if you go out to niles this weekend! I only have one battery so far, the others are on order. and i have to read these threads about "fixing" the twin hammers servo, which is kinda confusing to me since i'm a nooby.
SubyJeff is offline   Reply With Quote
Old 02-08-2013, 06:51 PM   #354
badger's Avatar
It has been asked, I'm using the stock gearing which works great with the ROC 412.
32p gearing IMO is not needed at all. Even with the awesome power the ROC 412 has and shifting gears at full throttle on 3s I have not had any issues with the 48p spur/pinion gears.
That's freaking awesome! I have two of the stock lipo's that I'm not going to use, you can have them. I'm trying to figure out where to take these on a night run tomorrow night with lights on the rigs. Let me know if your interested.
Old 02-08-2013, 06:55 PM   #355
I hope someone posts from vids of this unit doing some crawling
Hint hint lol
razors 33 is offline   Reply With Quote
Old 02-08-2013, 06:58 PM   #356
absolutely! just let me know
Old 02-08-2013, 08:40 PM   #357
ESC
Do you think you can make it wider so it can fit more easily a 2.2 set of tires?
ESC is offline   Reply With Quote
Old 02-08-2013, 08:42 PM   #358
badger's Avatar
I have no idea and honestly don't care to find out because I never plan on running 2.2's. I think they are too big and will just add extra weight and rotating mass that will more then likely break shit.
Old 02-08-2013, 08:48 PM   #359
More slow-mo please
701 Technique is offline   Reply With Quote
Old 02-08-2013, 08:50 PM   #360
ESC
well even though maybe just make it wider for estability?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/vaterra-twin-hammers/425908-badgers-vaterra-twin-hammers-1-9-rock-racer.html
Posted By For Type Date
Vaterra Twin Hammers 1/10 4WD Rock Racer - Seite 2 - RC Crawler - RC-Erdferkel This thread Refback 03-18-2013 12:32 PM
the exo's newest enemy This thread Refback 03-15-2013 11:59 PM
the exo's newest enemy - Page 3 - RCShortCourse.com Bulletin Board This thread Refback 03-10-2013 12:32 PM
Vaterra Twin Hammers 1/10 4WD Rock Racer - Seite 2 - RC Crawler - RC-Erdferkel This thread Refback 03-01-2013 08:14 PM
Vaterra & Horizon Hobby Products : radiocontrol This thread Refback 02-15-2013 10:00 PM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 5 - Jakspeed Racing - rockcrawler.de This thread Refback 02-15-2013 03:52 PM
Vaterra - Horizon Hobby's new brand - Page 5 - RC Groups This thread Refback 02-13-2013 12:22 PM
RCMT Review Crew want to do Twin Hammers review??? - Page 2 This thread Refback 02-12-2013 06:43 AM
the exo's newest enemy - Page 2 - RCShortCourse.com Bulletin Board This thread Pingback 02-10-2013 03:14 PM
vaterra twins hammer - Virgilio Ricerca Web This thread Refback 02-08-2013 02:54 PM
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Vaterra RC alguém conhece? This thread Refback 02-08-2013 08:53 AM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 4 - Jakspeed Racing - rockcrawler.de This thread Refback 02-08-2013 01:56 AM
- Neuer Hersteller: Vaterra - offroad-CULT This thread Refback 02-07-2013 03:24 AM
Vaterra Twin Hammers - jetzt wird gefahren... - Short Course, Desert Racing und Tamiya SRB - rockcrawler.de This thread Refback 02-06-2013 04:48 PM
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - VATERRA TWIN HAMMER REVIEW- NOVA MARCA DE RCS DA HORIZON This thread Refback 02-06-2013 03:37 PM
Er ist da - Vaterra Twin Hammers - Bilder - Die deutschsprachige HPI Baja Community This thread Refback 02-06-2013 11:57 AM
Er ist da - Vaterra Twin Hammers - Bilder - Die deutschsprachige HPI Baja Community This thread Refback 02-06-2013 11:47 AM
Vatis Doppelhammer, unboxing durch Sigi F. - Short Course, Desert Racing und Tamiya SRB - rockcrawler.de This thread Refback 02-06-2013 08:49 AM
Horizon Hobby releases new Brand Vaterra with some cool new RC models This thread Refback 02-05-2013 11:46 AM
Vaterra Twin Hammers This thread Refback 02-05-2013 08:00 AM
Vaterra rc - Twin Hammers 1/10 Rock Racer This thread Refback 02-04-2013 08:32 AM
• Thema anzeigen - Vaterra - Twin Hammers This thread Refback 02-04-2013 08:27 AM
Vaterra RC from Horizon Hobby - Page 2 - RC News - Modelsport UK Forum - Page 2 This thread Refback 02-04-2013 03:26 AM
Ny bil....men hvilken??? - Generel diskussion This thread Refback 02-03-2013 01:33 PM
Rock Racer - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 02-02-2013 05:59 PM
Horizon Hobby? Rock Racer, link This thread Refback 02-02-2013 02:34 PM
Vaterra "TWIN HAMMERS" 4WD Rock Racer. - Neuvorstellungen - RC-Monster-Trucks This thread Refback 02-02-2013 02:33 PM
Chase and Eggs - Page 108 - RCLargeScale.com This thread Refback 02-02-2013 02:05 PM
Mini Monster Club Romand • Consulter le sujet - Vaterra Twin Hammers, nouveau type de Scale... This thread Refback 02-02-2013 11:53 AM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 2 - Jakspeed Racing - rockcrawler.de This thread Refback 02-02-2013 04:45 AM
A.S.D.Trial Attack Racing Team - Online Users This thread Refback 02-01-2013 03:16 PM
Vaterra RC - Page 5 This thread Refback 02-01-2013 02:38 PM
vaterra - page 3 This thread Refback 02-01-2013 02:38 PM
4x4-Stubai - Neuer IFS Buggy: Vaterra Twin Hammers This thread Refback 02-01-2013 06:59 AM
Neuigkeiten 2013 - Bilder und Videos - rccrawler.eu This thread Refback 01-31-2013 11:06 PM
Novit da Horizon Hobby: VATERRA RC!! - Pagina 10 - Scalers & Crawlers This thread Refback 01-31-2013 04:55 PM
Twin Hammer rock racer This thread Refback 01-31-2013 03:25 PM
denna var tff This thread Refback 01-31-2013 02:01 PM
Mmmmm??? - Nostr Forums This thread Refback 01-31-2013 09:15 AM
Novit da Horizon Hobby: VATERRA RC!! - Pagina 7 - Scalers & Crawlers This thread Refback 01-31-2013 09:11 AM
Vaterra RC Twin Hammers IFS Desert Truck This thread Refback 01-31-2013 08:27 AM
Novit da Horizon Hobby: VATERRA RC!! - Pagina 7 - Scalers & Crawlers This thread Refback 01-31-2013 06:23 AM
Maritime Scale RC Forums - Vaterra Twin Hammers RTR Truck This thread Refback 01-31-2013 05:19 AM
the Crawl Pit • View topic - twin hammers This thread Refback 01-31-2013 01:07 AM
New Brand from Horizon coming tomorrow! - Page 2 - Oregon R/C Rock Crawlers This thread Refback 01-30-2013 09:24 PM
New Brand from Horizon coming tomorrow! - Page 2 - Oregon R/C Rock Crawlers This thread Refback 01-30-2013 09:10 PM
แฟนๆรถสเกว แต่ไม่ลืมที่จะโหดต้องดูนี่ครับ " Twin Hammers " This thread Refback 01-30-2013 07:41 PM
Scale RC - Page 396 - R/C Tech Forums This thread Pingback 01-30-2013 07:26 PM
LO NUEVO ....Twin Hammers 1.9 Rock Racer RTR by Vaterra - TwistedAndes This thread Refback 01-30-2013 03:38 PM
Novit da Horizon Hobby: VATERRA RC!! - Pagina 5 - Scalers & Crawlers This thread Refback 01-30-2013 02:44 PM
Badger's Vaterra Twin Hammers 1.9 Rock Racer - Similar Threads
Vaterra Twin Hammers Picture Archive - No talking Rock Concepts Vaterra Twin Hammers 328 01-23-2019 05:22 PM
Badger's Axial SCX10 Jeep JK w/ VP Currie Rock Axles badger Axial SCX-10 283 01-23-2016 08:04 PM
Video of Twin Hammers Rock Concepts Vaterra Twin Hammers 78 04-09-2013 06:55 AM
Twin Hammers Rock Concepts Videos! 4 01-31-2013 02:50 PM
NEW Vaterra Twin Hammers Discussion nissan_driver24 1.9 Scale Rigs 51 01-30-2013 01:47 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
