02-22-2013, 07:09 AM | #561 | |
Newbie Join Date: Jan 2013 Location: EEP
| Re: Badger's Vaterra Twin Hammers 1.9 Rock Racer Quote:
There is also an issue with the o-ring. This info is straight from the horse's mouth. Last edited by illthreat; 02-22-2013 at 08:31 AM. | |
02-22-2013, 11:52 AM | #562 |
RCC Addict Join Date: May 2011 Location: Utah County
I set my EPA's correctly and its hasn't died yet. But i noticed yesterday when i turn my tx off with the car still on that the shift servo freaks out and tries to shift back into first. So I just make sure to turn the car off first then the TX (which is what you SHOULD do anyways but i've always been sloppy on that since 2.4ghz radios came out and my cars stopped jumping off the workbench haha) Sent from my SCH-I535 using Tapatalk 2 |
02-22-2013, 06:11 PM | #563 |
Quarry Creeper Join Date: Dec 2012 Location: Canada
How do u adjust end points Remove horn Turn on vehicle Re center horn and use travel adjust to limit throw? |
02-23-2013, 11:07 AM | #564 |
Contact HH. They have a .docx and video on it. If anyone wants I can email it directly. Last edited by illthreat; 02-23-2013 at 11:54 AM. |
02-23-2013, 12:05 PM | #565 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
john@rccrawler.com Thanks. | |
02-23-2013, 12:06 PM | #566 |
Newbie Join Date: Feb 2013 Location: Louisville
I think where most people are having problems is having to use the stock radio pots to adjust the EPAs. Although it is a decent radio, it is not optimal for setting up the shift servo. You really need a radio that allows you to fine tune these adjustments digitally. I am using the DX3S and it makes setting it up a breeze. Just my two cents worth.
02-23-2013, 12:52 PM | #567 | |
The problem is multifaceted. 1. Epa not correctly set 2. Tx settings not consistent 3. O-ring 4. New product on the market Peace | |
02-23-2013, 12:53 PM | #568 | |
| Re: Badger's Vaterra Twin Hammers 1.9 Rock Racer Quote: Sent:-) | |
02-23-2013, 01:19 PM | #569 |
| Re: Badger's Vaterra Twin Hammers 1.9 Rock Racer |
02-24-2013, 05:26 AM | #570 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
I have mine setup with a 3 POSITION switch on a DX4S My rig stays in neutral and rolls free when not running and stays in the perfect neutral position when turned on. Before I start to drive I can decide what gear to shift into and it engages nice even when stopped. When on the fly just 2 quick clicks a let off the throttle a little,very smooth.Stock servo works fine I work at a hobby store and even though I had heard of the issue I pulled one out to use as a demo rig and to see how it would work right outa the box without touching a thing. Worked good for about 4 packs before the servo died but the thing I noticed everytime was no matter what position it's in every time you switch it on it twitches or clicks twice and tries to engage again and depending how smooth it engages the servo is under strain of coarse until the truck moves slightly and it fully locks in.Otherwise the end points were ok. |
02-24-2013, 08:49 AM | #571 |
Question guys As far as low end crawling would I like this or the newer axial Rubicon? |
02-24-2013, 09:28 AM | #572 |
Quarry Creeper Join Date: May 2012 Location: Gainesville
02-24-2013, 09:37 AM | #573 |
Ok thanks I assume the th is quicker out of the box though? |
02-24-2013, 09:43 AM | #574 |
02-24-2013, 10:37 AM | #575 |
Ok Thanks for info I am trying to figure out which is better for me, better value ect. The spectrum TX Is better than rtr axial I bet? |
02-24-2013, 10:54 AM | #576 |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
02-24-2013, 11:59 AM | #577 |
For adding a locker in front would that be really pricey?
02-24-2013, 12:21 PM | #578 |
Rock Stacker Join Date: Sep 2004 Location: Winston-Salem, NC
02-24-2013, 12:36 PM | #579 |
02-24-2013, 12:44 PM | #580 |
Ok Ill go with TH and add locker later I like lower cg anyways |
Badger's Vaterra Twin Hammers 1.9 Rock Racer - Similar Threads | ||||
Vaterra Twin Hammers Picture Archive - No talking | Rock Concepts | Vaterra Twin Hammers | 345 | 03-11-2024 05:55 PM |
Badger's Axial SCX10 Jeep JK w/ VP Currie Rock Axles | badger | Axial SCX-10 | 283 | 01-23-2016 08:04 PM |
Video of Twin Hammers | Rock Concepts | Vaterra Twin Hammers | 78 | 04-09-2013 06:55 AM |
Twin Hammers | Rock Concepts | Videos! | 4 | 01-31-2013 02:50 PM |
NEW Vaterra Twin Hammers Discussion | nissan_driver24 | 1.9 Scale Rigs | 51 | 01-30-2013 01:47 PM |
