Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Badger's Vaterra Twin Hammers 1.9 Rock Racer
Old 02-01-2013, 02:23 PM   #121
Default Re: Badger's Vaterra Twin Hammers 1.9 Rock Racer
Nice! 4.1" 1.9 maybe another option for C1 scalers. These tires look a lot bigger than 4.1". How does the compound of the tire feel Badger?
finishline is offline   Reply With Quote
Old 02-01-2013, 03:00 PM   #122
Diggin' the new SCX10 II!
badger's Avatar
Originally Posted by jthellfire911 View Post
got any 1.9 pitbulls to throw in it by chance? just to see the look?
I don't have any 1.9 pitbulls, just 2.2's. I think the 1.9 pitbulls might have to soft of a sidewall for high speed runs, would need really firm foams which would not be ideal for crawling.
Originally Posted by craigrobbo View Post
This would be ace, thanks a lot for this.
Gives a good idea of size!
No problem. Agreed.
Originally Posted by simon170 View Post
Thanks man. I know it might not look right, but it's always interesting to see with your own eyes
Which is why I'm going to mount the 2.2's, to each his own on how they want to build their rigs.
Even though the tires don't have "Losi" on the side, they are every bit as sticky and soft as my Losi comp claws or any of the other sticky comp tires out. When I took the took the tires off the rims yesterday to let the foams dry, I thought the tires were glued to the rims (even though they are on beadlocks) because I had to pull pretty good to peel the tire beads off the rims.
Bottom line, unless you absolutely hate the look or size of the stock tires, I don't see why anyone would want waste their money on new tires for this rig.
badger is offline   Reply With Quote
Old 02-01-2013, 03:03 PM   #123
FrankyRizzo's Avatar
Looks beefy. Looks like fun to drive.
FrankyRizzo is offline   Reply With Quote
Old 02-01-2013, 03:18 PM   #124
badger's Avatar
I was going to put 500K fluid in the front diff and tune it more for crawling but I'm wondering if I should leave it stock and take it over to Norcal Hobbies offroad track for some test laps with video first?
Think RECON Terra-X type event, I'm thinking this rig would be perfect for an event like that.
Old 02-01-2013, 04:25 PM   #125
Originally Posted by badger View Post
Will do. I think 2.2's are going to be way to big and not look right at all.
Buuuut people will do it anyway...lol
ev0l is offline   Reply With Quote
Old 02-01-2013, 04:28 PM   #126
Can you fit a standard 2s lipo hard pack in the back of that, or will I need to get new batteries?
erikstarcher is offline   Reply With Quote
Old 02-01-2013, 05:07 PM   #127
This would change the Terra-X event for the 1.9 class. As long as you lock or put a really heavy fluid in the front diff for the rock section.
nissan_driver24 is offline   Reply With Quote
Old 02-01-2013, 05:10 PM   #128
Rock Concepts's Avatar
It comes with a 2000 Lipo but you can upgrade to a 2s Shorty pack.
Twin Hammers 008 by 650schultz, on Flickr
Dynamite 7.4V 4000mAh 2S 30C LiPo, 96mm: 22 (DYN5306EC)
Twin Hammers 022 by 650schultz, on Flickr
DYN5306EL
Rock Concepts is offline   Reply With Quote
Old 02-01-2013, 05:29 PM   #129
This is the first 1.9 rig to call my name
frdtrkguy is offline   Reply With Quote
Old 02-01-2013, 05:41 PM   #130
Got my pre-order in.
tklatti is offline   Reply With Quote
Old 02-01-2013, 05:51 PM   #131
Thanks for all the pics and info here gents!
How is the crawling ability compared to something like a Wraith. I understand solid axle is just plain better for rock crawling but can the Twin Hammers at least keep up, somewhat?
I'm really torn between buying this or a Wraith. I want to be able to do a considerable amount of crawling and still trail ride at a decent pace.
LGrocks is offline   Reply With Quote
Old 02-01-2013, 05:52 PM   #132
Originally Posted by Rock Concepts View Post
It comes with a 2000 Lipo but you can up Grade to a 2s Shoty pack.
DYN5306EL
Thanks for the reply, but I was looking to see if a regular 2s hard case could be stuffed in between the shock towers. It would be nice to be able to use the boat load of 5000+ mah batts I already have and not have to spend another $100 on batteries that can only be used in this, and none of my other trucks.
Old 02-01-2013, 05:54 PM   #133
Originally Posted by scottanthony View Post
It'll prolly handle a Pro4......just not for long......48P..? What??
He asked what pitch the spur gear was. 48P was my answer to that question.
The only reason it would not be compatable with the pro 4 would be because of the 5mm shaft and the need to find a 5mm bore 48P pinion. Unless someone makes those by now. But the Dynamite 4 pole motors or the Castle ones will be just fine in this.
sdwk is offline   Reply With Quote
Old 02-01-2013, 07:00 PM   #134
I'm not a huge fan of scalers but this is sweet. I may have to look in to this. Does it kinda compare to the axial exo terra buggy?
donhd04 is offline   Reply With Quote
Old 02-01-2013, 07:32 PM   #135
I would like to see it on a track just out of curiosity. I may have missed it but have you weighed it yet?
MX304 is offline   Reply With Quote
Old 02-01-2013, 08:03 PM   #136
28 pinion and 78 spur... what's the transmission gear ratios?
i pre-ordered so i guess i'll see what the speeds are at high and low.
BKcrawler is offline   Reply With Quote
Old 02-01-2013, 08:13 PM   #137
I want!
The Luke is offline   Reply With Quote
Old 02-01-2013, 09:03 PM   #138
One of the new Tekin ROC motors would be awesome in this thing.
Old 02-01-2013, 09:05 PM   #139
This has got me more excited for a rtr truck than anything else in a long time, thanks for all the nice spec shots badger
701 Technique is offline   Reply With Quote
Old 02-01-2013, 09:33 PM   #140
badger's Avatar
Good catch, I forgot to weigh it. I'll take it down to the P.O. tomorrow to see what she weighs.
I've been contemplating raping the ROC 412 out of my SCX10 JK to try in this rig because I like the ROC 412 motor so much. With the 2 speed it should be awesome in low for crawling and then have some kick ass speed high.
My pleasure, thanks.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/vaterra-twin-hammers/425908-badgers-vaterra-twin-hammers-1-9-rock-racer.html
Posted By For Type Date
Vaterra Twin Hammers 1/10 4WD Rock Racer - Seite 2 - RC Crawler - RC-Erdferkel This thread Refback 03-18-2013 12:32 PM
the exo's newest enemy This thread Refback 03-15-2013 11:59 PM
the exo's newest enemy - Page 3 - RCShortCourse.com Bulletin Board This thread Refback 03-10-2013 12:32 PM
Vaterra Twin Hammers 1/10 4WD Rock Racer - Seite 2 - RC Crawler - RC-Erdferkel This thread Refback 03-01-2013 08:14 PM
Vaterra & Horizon Hobby Products : radiocontrol This thread Refback 02-15-2013 10:00 PM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 5 - Jakspeed Racing - rockcrawler.de This thread Refback 02-15-2013 03:52 PM
Vaterra - Horizon Hobby's new brand - Page 5 - RC Groups This thread Refback 02-13-2013 12:22 PM
RCMT Review Crew want to do Twin Hammers review??? - Page 2 This thread Refback 02-12-2013 06:43 AM
the exo's newest enemy - Page 2 - RCShortCourse.com Bulletin Board This thread Pingback 02-10-2013 03:14 PM
vaterra twins hammer - Virgilio Ricerca Web This thread Refback 02-08-2013 02:54 PM
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Vaterra RC alguém conhece? This thread Refback 02-08-2013 08:53 AM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 4 - Jakspeed Racing - rockcrawler.de This thread Refback 02-08-2013 01:56 AM
- Neuer Hersteller: Vaterra - offroad-CULT This thread Refback 02-07-2013 03:24 AM
Vaterra Twin Hammers - jetzt wird gefahren... - Short Course, Desert Racing und Tamiya SRB - rockcrawler.de This thread Refback 02-06-2013 04:48 PM
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - VATERRA TWIN HAMMER REVIEW- NOVA MARCA DE RCS DA HORIZON This thread Refback 02-06-2013 03:37 PM
Er ist da - Vaterra Twin Hammers - Bilder - Die deutschsprachige HPI Baja Community This thread Refback 02-06-2013 11:57 AM
Er ist da - Vaterra Twin Hammers - Bilder - Die deutschsprachige HPI Baja Community This thread Refback 02-06-2013 11:47 AM
Vatis Doppelhammer, unboxing durch Sigi F. - Short Course, Desert Racing und Tamiya SRB - rockcrawler.de This thread Refback 02-06-2013 08:49 AM
Horizon Hobby releases new Brand Vaterra with some cool new RC models This thread Refback 02-05-2013 11:46 AM
Vaterra Twin Hammers This thread Refback 02-05-2013 08:00 AM
Vaterra rc - Twin Hammers 1/10 Rock Racer This thread Refback 02-04-2013 08:32 AM
• Thema anzeigen - Vaterra - Twin Hammers This thread Refback 02-04-2013 08:27 AM
Vaterra RC from Horizon Hobby - Page 2 - RC News - Modelsport UK Forum - Page 2 This thread Refback 02-04-2013 03:26 AM
Ny bil....men hvilken??? - Generel diskussion This thread Refback 02-03-2013 01:33 PM
Rock Racer - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 02-02-2013 05:59 PM
Horizon Hobby? Rock Racer, link This thread Refback 02-02-2013 02:34 PM
Vaterra "TWIN HAMMERS" 4WD Rock Racer. - Neuvorstellungen - RC-Monster-Trucks This thread Refback 02-02-2013 02:33 PM
Chase and Eggs - Page 108 - RCLargeScale.com This thread Refback 02-02-2013 02:05 PM
Mini Monster Club Romand • Consulter le sujet - Vaterra Twin Hammers, nouveau type de Scale... This thread Refback 02-02-2013 11:53 AM
Neu bei Jakspeed Racing = Vaterra Twin Hammers 1/10 4WD Rock Racer (Horizon Hobby) - Seite 2 - Jakspeed Racing - rockcrawler.de This thread Refback 02-02-2013 04:45 AM
A.S.D.Trial Attack Racing Team - Online Users This thread Refback 02-01-2013 03:16 PM
Vaterra RC - Page 5 This thread Refback 02-01-2013 02:38 PM
vaterra - page 3 This thread Refback 02-01-2013 02:38 PM
4x4-Stubai - Neuer IFS Buggy: Vaterra Twin Hammers This thread Refback 02-01-2013 06:59 AM
Neuigkeiten 2013 - Bilder und Videos - rccrawler.eu This thread Refback 01-31-2013 11:06 PM
Novità da Horizon Hobby: VATERRA RC!! - Pagina 10 - Scalers & Crawlers This thread Refback 01-31-2013 04:55 PM
ùàìä Twin Hammer rock racer This thread Refback 01-31-2013 03:25 PM
denna var tøff This thread Refback 01-31-2013 02:01 PM
Mmmmm??? - Nostr Forums This thread Refback 01-31-2013 09:15 AM
Novità da Horizon Hobby: VATERRA RC!! - Pagina 7 - Scalers & Crawlers This thread Refback 01-31-2013 09:11 AM
Vaterra RC Twin Hammers IFS Desert Truck This thread Refback 01-31-2013 08:27 AM
Novità da Horizon Hobby: VATERRA RC!! - Pagina 7 - Scalers & Crawlers This thread Refback 01-31-2013 06:23 AM
Maritime Scale RC Forums - Vaterra Twin Hammers RTR Truck This thread Refback 01-31-2013 05:19 AM
the Crawl Pit • View topic - twin hammers This thread Refback 01-31-2013 01:07 AM
New Brand from Horizon coming tomorrow! - Page 2 - Oregon R/C Rock Crawlers This thread Refback 01-30-2013 09:24 PM
New Brand from Horizon coming tomorrow! - Page 2 - Oregon R/C Rock Crawlers This thread Refback 01-30-2013 09:10 PM
à¹à¸Ÿà¸™à¹†à¸£à¸–สเà¸à¸§ à¹à¸•à¹ˆà¹„ม่ลืมที่จะโหดต้องดูนี่ครับ " Twin Hammers " This thread Refback 01-30-2013 07:41 PM
Scale RC - Page 396 - R/C Tech Forums This thread Pingback 01-30-2013 07:26 PM
LO NUEVO ....Twin Hammers 1.9 Rock Racer RTR by Vaterra - TwistedAndes This thread Refback 01-30-2013 03:38 PM
Novità da Horizon Hobby: VATERRA RC!! - Pagina 5 - Scalers & Crawlers This thread Refback 01-30-2013 02:44 PM
Badger's Vaterra Twin Hammers 1.9 Rock Racer - Similar Threads
Vaterra Twin Hammers Picture Archive - No talking Rock Concepts Vaterra Twin Hammers 345 03-11-2024 05:55 PM
Badger's Axial SCX10 Jeep JK w/ VP Currie Rock Axles badger Axial SCX-10 283 01-23-2016 08:04 PM
Video of Twin Hammers Rock Concepts Vaterra Twin Hammers 78 04-09-2013 06:55 AM
Twin Hammers Rock Concepts Videos! 4 01-31-2013 02:50 PM
NEW Vaterra Twin Hammers Discussion nissan_driver24 1.9 Scale Rigs 51 01-30-2013 01:47 PM
