Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Vaterra Race Claw tires?
Old 02-01-2013, 11:57 AM   #1
Natedog's Avatar
Default Vaterra Race Claw tires?
These new tires look like they would be really good on my SCX.
Anybody have a pic of Vaterra 1.9 Race Claw tires next to Proline 1.9 Flat Irons?
Old 02-01-2013, 02:26 PM   #2
Default Re: Vaterra Race Claw tires?
In Badgers build he said the tire size is 4.1" the Flatiron is 4.2". Trying to find out what the compound of the tire is or feels like.
finishline is offline   Reply With Quote
Old 02-01-2013, 03:22 PM   #3
And the answer is...
Originally Posted by badger View Post
Even though the tires don't have "Losi" on the side, they are every bit as sticky and soft as my Losi comp claws or any of the other sticky comp tires out. When I took the took the tires off the rims yesterday to let the foams dry, I thought the tires were glued to the rims (even though they are on beadlocks) because I had to pull pretty good to peel the tire beads off the rims.
Bottom line, unless you absolutely hate the look or size of the stock tires, I don't see why anyone would want waste their money on new tires for this rig.
crazy81 is offline   Reply With Quote
Old 02-01-2013, 03:27 PM   #4
Blue compound just like the Comp/Rock Claws
Rubbaneck is offline   Reply With Quote
Old 02-01-2013, 03:52 PM   #5
Rock Concepts's Avatar
Twin Hammers 019 by 650schultz, on Flickr
Rock Concepts is offline   Reply With Quote
Old 02-01-2013, 05:09 PM   #6
Natedog's Avatar
Many tires do not measure exactly true, so I would like to see next to Flat Irons, a tire that most everybody knows and Im' running a couple sets (un-cut and cut up tread patterns) on my 1.9er now.
Old 02-01-2013, 05:23 PM   #7
That's because every rig is different weight, foams, suspension set up and COG. All that is going to change how tall a tire sits on a rig. But if you take the tire and lay it on its side it will measure true unless its stuffed with stiff foam.
Old 02-01-2013, 05:51 PM   #8
Natedog's Avatar
That is true about installed height, but not every tire is true to it's dimensions printed on the sidewall either.
Old 02-01-2013, 05:53 PM   #9
Natedog's Avatar
Thanks Rock Concepts for the pic. I"m wishing they were 4.2" tall.
Old 02-02-2013, 07:40 PM   #10
thats hardly a difference worth noticing!
JJBTEXAS is offline   Reply With Quote
Old 02-02-2013, 09:39 PM   #11
Natedog's Avatar
When you got small tires to start with, it's a lot.....1.4% height difference.
Old 02-02-2013, 09:49 PM   #12
Old 02-02-2013, 09:52 PM   #13
Natedog's Avatar
Lol
Old 02-05-2013, 08:24 PM   #14
I bet a wood pecker wouldn't say that about his pecker . Now would he ?
Badd is offline   Reply With Quote
Old 02-13-2013, 08:58 PM   #15
Heres tires next to tsl boggers,rocklox,&flatirons.
tklatti is offline   Reply With Quote
Old 02-13-2013, 10:52 PM   #16
Metal shaper
I measured my tires today with calipers and the were 4.300
Pic next to my Pitbulls which measured 4.550.
Both mounted on wheels
CarterFab is offline   Reply With Quote
Old 02-14-2013, 08:59 AM   #17
I cut my race claws similar to how I cut my flat irons and found they perform way way way better. This is the best pic I have of it for now. Going to work and dont have time to get a better shot. I also replaced the rock hard foams with ci med front and ci firm rear, all cheap $2 single stage stuff, it works great for me now crawling and bashing.
Sheepdawg23wm is offline   Reply With Quote
Old 02-14-2013, 09:07 AM   #18
Metal shaper
Alert!!
These things have a massive bead seat area. I was going to mount them on my TSS 1.9 Robby Gordon wheels but that ain't happening.
I'm just going to modify the stock wheels a bit and add a little weight for scaler applications. The stock wheels have a massive center channel which will be nice for adding weight internally.
I have also sent MThead the ring dimensions so you will be able to order custom delrin rings from him.
On another note, anyone who has ever owned 1:1 beadlocks knows how the rings taper inwards once torqued. Vaterra went so far as to design this into their rings. Hats off guys. Very cool for us scale fanatics. I think I'll be adding scale hardware to mine this weekend and drilling the rings for faux hardware.
Old 02-15-2013, 04:56 PM   #19
Metal shaper
News flash!!
I didn't even check before hand but as it turns out, the bead lock rings are the same as axials 1.9s. You can go ahead and order any of the popular delrin rings from Mthead or the aluminum rings from Locked Up RC. Or run the the super scale Vaterra rings on your axial wheels.
Old 02-15-2013, 05:07 PM   #20
Anyone notice that these tires also come vented
Rockridge is offline   Reply With Quote
Vaterra Race Claw tires? - Similar Threads
Anybody got measurements on Claw MT tires? chronicspd Tamiya Clod Buster 0 10-03-2008 08:57 PM
Losi Claw MT tires? jlmotox Tamiya Clod Buster 2 03-18-2008 02:30 AM
Claw MT/LST tires hotwheels000 Tires and Wheels 35 05-06-2007 07:17 AM
