LED lights in the stock light housings Hello :) i want to keep the stock light housings (4 on top, 2 in front) and put LEDs behind them. i was going to pick up one of these kits to hold the lights, then drilling holes in the stock panels Amazon.com: RPM Roof Mount Light Bar Set, Chrome: SLH RPM80923: Toys & Games my question is, what LED electronics should i buy? this would be for powering 6 white LEDs. thanks! "thumbsup" |
Re: LED lights in the stock light housings It is a lot of work because the cage is in the way. This is what i have so far i used a integy kit with axial light covers. http://i159.photobucket.com/albums/t...psf6c5563e.jpg |
Re: LED lights in the stock light housings i wanted to get the axial light bar set, but the set is only 5 lights and the twin hammers has 6 was also looking at this light bar set Amazon.com: Pro-Line HID Crawler/Desert Truck Light Bar Kit: Toys & Games but i need to know what LED / electronics to get :) like this ? http://www.rpphobby.com/product_p/rcl106.htm |
Re: LED lights in the stock light housings I was going to use the axial simple light kit and just replace the 2 red leds with a couple of whites ones that I didn't use in another build. It just plugs into the receiver. I have a bunch of axial light buckets and lenses and was hoping that those would fit into the holes in the body. Guess we'll find out when I get mine (hopefully this week!!) |
Re: LED lights in the stock light housings You can't run two separate sets of white lights on the simple controller, but you can cut and solder a set of 4 and a set of 2 and use the one plug. That leaves a plug for red. The white/clear lights and reds run on different voltages... Learned this with my Exo. |
Good info. I did not know that. I have the pieces to do what you're talking about though. |
