07-29-2013, 02:43 AM | #61 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
08-03-2013, 10:59 AM | #62 | |
Quarry Creeper Join Date: Dec 2012 Location: Canada
| Re: Brushless System Opinion - Which is Best for MY needs?
Still happy with this set up? Quote:
08-04-2013, 04:44 PM | #63 |
Rock Crawler Join Date: May 2012 Location: Upland
I have an ae2 and Integy 35 in my th right now. I'm planning on putting a Tekin rs and Orion V2 17.5 in it. Not sure how to gear it but it looks like I can change out the pinion and set the mesh with the trans and motor installed in the vehicle. Thinking of running 0 degrees can timing, near max boost over full rpm range, and current limiter to 70% or so. Sent from my PG86100 using Tapatalk 2 |
08-04-2013, 04:45 PM | #64 |
Double post
08-05-2013, 07:22 AM | #65 |
Quarry Creeper Join Date: Oct 2011 Location: Waterford
Mamba max pro, tekin roc 412 3100kv, on 3s. Sent from my MB855 using Xparent BlueTapatalk 2 |
08-11-2013, 09:57 PM | #66 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| Re: Brushless System Opinion - Which is Best for MY needs? Before I got my 10.5T motor to play with, I used the Spin Super with a 17.5T, and I will probably re-solder new connections on it to swap out with my fast motor when I want. The Spin Super is an alright esc, but it lacks a lot of nice features. Even though I use my TH to bash and race with my slashes, I would still like a drag brake, which the LRP does not have. But with a 17.5T Sensored brushless motor, I had no real issues with being able to creep slow, nor do I with my 10.5T. And I even have my Shift servo disconnected since it fried and I haven't fitted my HiTec one in yet, though I imagine that will be pretty fun, too.
08-13-2013, 02:29 AM | #67 |
Running a Tekin Rs and a Orion V2 17.5 now. 5 degrees can timing. ESC settings: 75% current limiter. 60% reverse power. 10 points timing. 15 points boost over 5k to 25k rpm. 70% drag brake. I have a 32 tooth pinion gear and the motor never gets hot, just warm. I may gear it taller. It crawls nicely and has good wheel speed for blipping the throttle in first gear. Second gear isn't too tall and can be used to bash while hill climbing. I will probably keep gearing up. I have up to 37 tooth, I believe. I was racing blinky 17.5 buggy at ocrc for a while. Gotta have big ol pinions! Or I may add more boost and watch temps. Sent from my PG86100 using Tapatalk 2 |
09-09-2013, 08:00 PM | #68 |
hey guys, I'm wondering if you guys think this esc/motor combo would work in the TH? Novak Crusher 2S-4S Crawler Brushless Motor Combo (18.5T) [NOV3258] | RC Cars & Trucks - A Main Hobbies |
09-09-2013, 09:41 PM | #69 |
Newbie Join Date: Aug 2008 Location: Cloverdale
I use the LT4 in 3 of my rigs, Twin Hammers with Novak 13.5 and SCX10 with a Novak 13.5 and Losi 22 with a 17.5 not one problem in over a year. Great ESC for the price point. Love the use of the software. |
09-09-2013, 10:48 PM | #70 |
Pebble Pounder Join Date: Jul 2013 Location: San Bernardino
Does anyone have any experience with this set up? Novak Timbuk2 Crawler Brushless ESC/Ballistic Crawler Brushless System (13.5T) [NOV3223] | RC Cars & Trucks - A Main Hobbies |
09-10-2013, 11:52 AM | #71 |
I'd like really like to run 3S set up but still have great slow control for crawling
09-10-2013, 07:58 PM | #72 | |
Rock Crawler Join Date: May 2013 Location: Dallas
| Re: Brushless System Opinion - Which is Best for MY needs? Quote:
I personally run most of my rigs in the 2400KV area on 3-4S and gear accordingly. The 18.5t you posted is going to be hard to get enough wheel speed from without throwing a bunch of volts at it. | |
09-10-2013, 08:00 PM | #73 | |
Ok thanks Can you recommend a good set up that is well balanced for crawling and better than stock speed? I have plenty of 3S 2200's I like to use if possible Quote:
09-10-2013, 08:15 PM | #74 | |
Everyone seems to be on the ROC412 bandwagon right now, which isn't bad. But IMO this much power is difficult to drive with. I use a Novak Ballistic 550 8.5T 2400KV in mine running 2100mah 3S lipos and I LOVE this. It honestly puts me in about the same power range as a ROC412 even though it's a 550 because it's only 2 pole, but it runs cooler than a 540 size can due to the surface area difference, there's just more available heat-transfer area. I was also in constant fear of breaking my transmission, and even with the upgraded gears you're still transmitting the power through a plastic part on it's way out of the trans and no one has addressed this problem yet. For a brief period I ran a 3300kv 2 pole and I was extremely pleased with the wheel speed in 2nd gear and it was as crawlable as a non sensored brushless can get in 1st gear. I'm sure if I had a sensored motor in this range it would be fantastic. I would shoot for somewhere around it as a sweet spot. My driving style and locations require brutal, on demand torque for jumping over the rocks I can't climb over, this is why I choose to run lower in the KV and gear it for the wheel speed I want. Unless you're honestly willing to throw too much money at a TWH, I'd stick with a 3300kv ish 2 pole. Really, there's so many good companies out there you can just pick one in your budget range and go with it other than maybe avoiding Novak brushless speed controllers. I wouldn't hesitate to get a HobbyWing LT4 a decent sensored motor, but I won't buy anything other than an Mamaba Max Pro for something this size. I've had fantastic luck with them. I have 4 rigs with them currently, one of which has had the same electronics in it for almost 3 years and gets driven hard. Last edited by DrewHammer; 09-10-2013 at 08:17 PM. | |
09-10-2013, 08:31 PM | #75 |
ok, so a 3300 kv, 2 pole motor sensored and appropriate esc is in order.
Tags |
basher, brushless, castle, novak, twin hammers |
