Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: My Hammer so far.
Old 02-22-2013, 11:26 AM   #21
Default Re: My Hammer so far.
So did not like the way the stock shocks were leaking so put some big bores on.
Much better.
MR.VERTICAL is offline   Reply With Quote
Old 02-22-2013, 04:58 PM   #22
Originally Posted by MR.VERTICAL View Post
So fare I like the way they work going out Saturday for some real testing.
Cool. Please keep me posted!
ProjectSCX10 is offline   Reply With Quote
Old 02-22-2013, 06:17 PM   #23
which shocks are those?
Sent from my SGH-T989 using Tapatalk 2
bonedog is offline   Reply With Quote
Old 02-22-2013, 06:53 PM   #24
Traxxas 4in big bore with DUBRO 3mm heavy duty ball links #2321
Old 02-25-2013, 03:13 PM   #25
Was trying the MadDog 4in light bar today and it bolts right up
Old 02-26-2013, 07:04 PM   #26
Worken on some thing new for the front end.
Old 02-26-2013, 08:10 PM   #27
What do you have in store now? Battery plate?
You going to put the rigid light back on?
shwng1973 is offline   Reply With Quote
Old 02-26-2013, 08:54 PM   #28
Which thunder power lipo is that on the back? the 2650?
kikcaffine is offline   Reply With Quote
Old 02-26-2013, 11:03 PM   #29
I have two back there a 3c 2100 to run on and a 3c 350 to run the light.
Old 02-27-2013, 06:37 PM   #30
new shocks.
Old 02-27-2013, 07:57 PM   #31
new shocks.
Interesting. Will have to see how this turns out.
Sent from my DROIDX using Tapatalk 2
wrightcs77 is offline   Reply With Quote
Old 02-28-2013, 12:20 AM   #32
perfictsib's Avatar
never mid the shocks i can see what looks like a cf shock plate
perfictsib is offline   Reply With Quote
Old 02-28-2013, 10:32 AM   #33
After weeks of tuning it's now a rock crawler got redd of the rear sway bar put longer shock up front much smoother then the stock ones .
front 65w oil with red 3.9o spring 3.5 big bores limited 12mm
rear 30w oil with white 1.90 spring 4.0 big bores
Old 02-28-2013, 10:40 AM   #34
8-454's Avatar
Did you mount the upper end of the shocks at the trans brace screws?
Looks killer!
8-454 is offline   Reply With Quote
Old 02-28-2013, 10:45 AM   #35
Looks killer!
Yep could have moved it back another 5mm but took the easy way.
Old 02-28-2013, 01:46 PM   #36
Can you explain more on how you changed the shock mount/chassis plate. Maybe show some pictures?
I know the stock one is a weak point, and one made from aluminum can crush the transmission. Yours seems to be longer than the stock.
I'd figure it out myself, but my truck isn't in my hands yet :(
Old 03-04-2013, 12:01 PM   #37
Quick mod to the rear.
And can still get to the battery.
Old 03-04-2013, 04:24 PM   #38
Some new goodies up front.
Old 03-04-2013, 05:21 PM   #39
Any more steering added?
Erin is offline   Reply With Quote
Old 03-04-2013, 05:39 PM   #40
heinie_21's Avatar
X2
Sent from my SCH-I535 using Tapatalk 2
heinie_21 is offline   Reply With Quote
My Hammer so far. - Similar Threads
Who still using PL Hammer tires? Sylvain Tires and Wheels 21 06-21-2020 07:00 PM
Got my twin hammer moore4x4 Vaterra Twin Hammers 5 02-15-2013 10:30 PM
Chisel vs. Hammer? Barillms Tires and Wheels 10 01-08-2010 05:46 AM
Hammer G8 compound. HRT5SLCFD Tires and Wheels 4 03-29-2009 06:35 PM
