Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Rear Sway Bar Questions (Pic Request)
Old 02-23-2013, 10:55 PM   #21
Default Re: Rear Sway Bar Questions (Pic Request)
Another hope is that Vaterra or aftermarket will release different ratio rockers that alter the ratio (force) that is placed on the front shocks while the front compresses. This is a very useful tuning option on the 10th Revo.
wrightcs77 is offline   Reply With Quote
Old 02-23-2013, 11:03 PM   #22
Originally Posted by MR.VERTICAL View Post
Looks like Losi still hasnt figured out that whole "leaky shock" thing...
JeremyH is offline   Reply With Quote
Old 02-24-2013, 05:20 AM   #23
That's a understatement! Hell mine were leaking right out of the box, oil on all four shock shaft and the fronts were only half full. Then i put heavier springs on mine to find out that the stock plastic spring preload collars are not up to the task a they just slip up under any load. Glad I'm switching out all four shock once they get delivered.
Kzzican is offline   Reply With Quote
Old 02-24-2013, 06:27 AM   #24
The picture of the rockers on Horizon show 4 rockers in that part #. So it looks like they have 2 ratios. Anyone check of 1/16 revo rockers fit?
cherokee95 is offline   Reply With Quote
Old 02-24-2013, 09:11 AM   #25
Those 4 pieces make a complete pair of factory rockers. Each rocker arm is actually two pieces that fit together, sandwiching the rod ends... Commonly referred to as "double shear".
SStone is offline   Reply With Quote
Old 02-24-2013, 04:20 PM   #26
Revo rockers are a bit bigger. Not the best pic, but I just grabbed it off the shelf. Ill break it down further and post some side y sides.
Soulo747 is offline   Reply With Quote
Old 04-02-2013, 03:34 PM   #27
Di you have pictures of the revo side to side with the Vaterra???
Matias del Rio is offline   Reply With Quote
Old 04-20-2013, 11:05 PM   #28
what bar you guys using for crawling? I just put in the lightest bar tonight to see how I like it; the middle was too much for crawling/trail truck. And I found it made the truck flip more on grass. The front end of this rig is very responsive; hard to keep it from doing donuts on payment with a little sand lol
razors 33 is offline   Reply With Quote
Old 04-22-2013, 10:01 AM   #29
Dang thanks for the sway bar pic, I'm installing mine today, which spring u using soft, med, or hard?
I'm thinking of starting in the middle with the medium...
Rastaman is offline   Reply With Quote
Old 04-22-2013, 12:41 PM   #30
I found medium too much and rear wouldn't articulate as much.
I don't find that mine handles, any better either, if anything it seems to flip more now and, I've been messing with front spring to adjust. High speed turns on grass always result in rollovers
Old 04-22-2013, 12:50 PM   #31
It depends on your use of the TH. When I was running it at high speed, the hard ones were awesome. The soft ones were decent in the rocks, but under fast acceleration it would spin out. I'm running a brushless by the way.
Coastie07 is offline   Reply With Quote
Old 04-22-2013, 01:10 PM   #32
The front end just grabs like crazy. Even on payment with a little sand it ls all too easy to spin out or do donuts all day long.
I find if I am wanting to go fast I dial down the steering throw and its better, but then dial it back up when trail running or on rocks
Old 04-23-2013, 01:49 AM   #33
Hello. Could somebody take a photo from a side to see the upper sway bar mount? Thank you!!!
This item is actually out of stock.... so Im thinking about to make my own sway bar with a link, what do you think? It is posible?
Thank you very much for your help!!!
EDIT: Ive just see that I need more elemnt that a simple link!!!! So I have to wait.....
Thank you!!
carcueza is offline   Reply With Quote
Rear Sway Bar Questions (Pic Request) - Similar Threads
LTB rear sway bar kit Kzzican Vaterra Twin Hammers 5 02-20-2013 10:41 PM
Rear mounted sway bar. oneeye Vaterra Twin Hammers 3 02-19-2013 07:00 AM
Made a rear Sway Bar for a Speed Run !! Toyo496 HPI Wheely King 1 03-30-2010 11:47 PM
