Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: transmission shift shaft isn't smooth
Old 02-26-2013, 10:16 PM   #1
Default transmission shift shaft isn't smooth
Having some problems with my tranny shift shaft controlled by the shift servo. it does not glide back and forth smooth at all, it sticks too much. i tried a dab of lube but it still doesn't glide.
i took the arm off the shift servo and tried to pull/push it, and it keeps getting stuck a lot.
any body else with this problem? advice?
SubyJeff is offline   Reply With Quote
Old 02-27-2013, 04:17 AM   #2
Default Re: transmission shift shaft isn't smooth
Are you shifting while the wheels spin, it's not design to shift while stopped.
Tgreer is offline   Reply With Quote
Old 02-27-2013, 08:45 AM   #3
correct
what i'm talking about however, when i put it into a neutral state (roll forward where the cogs line up and you can push/pull the arm in/out), as mentioned, the arm does not glided back and forth smoothly.
it sticks and slips, like friction most of the time.
Old 02-27-2013, 09:28 AM   #4
Hhhmm, I'm not sure then! From your pic it looks like grooves are scraped across that rod through the grease, you might pull that apart and clean everything really well to make sure your not getting any kind of grit through that shaft. I also wonder if you would be better to use something like wd40 or dry lube instead of grease.
Old 02-27-2013, 09:32 AM   #5
i did use a lube
it might be a micro grit built up making it scrape on the hole in the tranny case causing it stick/slip.
Old 02-27-2013, 01:50 PM   #6
Have the same problem but did not yet try anything. I guess I will try rebuilding the gear/shifting block completely.
Sabrelux is offline   Reply With Quote
Old 02-27-2013, 02:10 PM   #7
heinie_21's Avatar
Originally Posted by SubyJeff View Post
i did use a lube
ohhh this WHOLE post has a double meaning. are you trying to tell us something jeff?
heinie_21 is offline   Reply With Quote
Old 02-27-2013, 02:18 PM   #8
well this whole subforum is! People talking about their Hammers, shafts, lube, trannies, madness!
Old 02-27-2013, 02:41 PM   #9
If you need that part I have an extra from Horizon they sent me.
That part you circled should be smooth. As the marks would not be coming from the gears inside. The marks would be up and down not side to side.
shwng1973 is offline   Reply With Quote
Old 04-14-2013, 08:40 PM   #10
I have the same issue. Took mine apart and the cheap cast aluminum shift fork is pivoting on the shaft just enough to let it bind up and not shift.
maxxdrive is offline   Reply With Quote
transmission shift shaft isn't smooth - Similar Threads
Heavy duty transmission gear plus titanium shaft Indra Axial Wraith 5 12-25-2012 01:16 PM
transmission output shaft :( meanbgreen Axial SCX-10 15 11-18-2011 02:41 PM
Broken Transmission output shaft sbarnesvta Axial AX-10 Scorpion 6 03-25-2009 01:35 PM
Transmission output shaft MaXX_CrAWlER7 Axial AX-10 Scorpion 3 03-23-2008 07:39 AM
