Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! Vaterra Twin Hammer Shift Servo Mount Tired of blowing up those tiny shift servos?? Go Full size!!! Now you can our full size servo mount that bolts directly in place of the stock mini servo. This is designed to use your factory parts to save you some money. Super Thin so it doesn't add extra height to your servo for body clearance... Includes: .030 Carbon Servo plate 3mm nut 3mm Flat Head Screw Weight: Only 2g Click Here for more pics and pricing http://chaoticcrawlers.com/TH%20mount-1.jpg http://chaoticcrawlers.com/TH%20mount-3.jpg http://chaoticcrawlers.com/TH%20mount-6.jpg |
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! Pretty simple to install...But here is a quick how to... Basic pic with the new servo plate and trans....Includes the super thin plate, screw and a 3mm nut. http://i373.photobucket.com/albums/o...psd3daf354.jpg I started putting in the new tapered screw first. To prevent possible splitting of the trans hole I recommend taking a drill bit or body reamer slightly to the top of the hole before installing the mount. Then I used the stock screw and servo post from the stock mini servo. Once both in I tightened them both down. http://i373.photobucket.com/albums/o...psa9383ca8.jpg http://i373.photobucket.com/albums/o...psaf0b6123.jpg Next put on the other servo post supplied in TH kit. This is where you use the supplied nut to tighten it. http://i373.photobucket.com/albums/o...ps8b991524.jpg Put the full size servo of choice on the plate and use the stock screws to hold it tight. The stock servo posts only allow you to hit the bottom two screws. This is plenty strong. BUT...If you want this mount also accommodates aftermarket full size servo posts. http://i373.photobucket.com/albums/o...ps135785f3.jpg Connect up your stock shift linkage and Wallahh...No more worrying how long the mini servo will last... Set your end points and enjoy!!! http://i373.photobucket.com/albums/o...ps4dd56cc5.jpg |
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! did that screw hole crack where the new tapered screw went into? |
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! It cracked on a previous mount attempt... FYI do not over tighten!! Haha Still seems super strong though!! |
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! Quote:
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! Wallahh! lol |
Re: Chaotic TH Full Size Shift Servo Plate - Carbon Fiber!! We have temporarily lowered the price on these for an Introductory SALE... Please check them out on our website for the updated Price. All the orders made to date will be refunded the Sale difference...Thanks for the support!!! "thumbsup""thumbsup" |
