Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Hawaiian hammah time
Old 03-05-2013, 01:59 AM   #21
Default Re: Hawaiian hammah time
I got a care package from horizon today! New shift servo, steering servo and 4 shock over haul kits.
I also got more work done to the front cage tonight, still need to gusset the shock hoops.
spitfireat808 is offline   Reply With Quote
Old 03-05-2013, 02:09 AM   #22
Ohh I for got to post this haha! Here my custom rear sway bar made of spring steel and the hardware from a mega tech 4wd nitro car
The tub mounting is only temporary till I make some aluminum brackets.
Old 03-07-2013, 06:40 AM   #23
Here's my latest work I've got done, installed a new 9157 futaba steering servo, power HD 1501 servo with internal yea racing winch controller, a new set of 1.9 gearhead hammer wheels and 32 pitch gears.
12T 32p Novak gear. Note that this gear needs to be installed on the motor first before mounting it to the transmission due to clearance issues.
A very nice and tight fit ;)
32p 56t AE gear.
Servo winch installed with delrin fairlead.
Here's a short video of the winch in action. This rig is about 5lb 12oz .
1.9 PB w/gearhead hammers
Old 03-07-2013, 06:57 AM   #24
looking good bruda mange!!
ROLANDROCKSHOP is offline   Reply With Quote
Old 03-07-2013, 10:35 AM   #25
Beeyootiful! Is 12/56 (32p) close to stock gearing?
Soulo747 is offline   Reply With Quote
Old 03-07-2013, 11:07 AM   #26
heinie_21's Avatar
no
28/78 is stock. that's about 2.78.
12/56 is about 4.66.
I think the spur would have to be about 33t to keep the stock ratio with a 12t pinion. So its a slower ratio by far, is that right?
heinie_21 is offline   Reply With Quote
Old 03-07-2013, 12:55 PM   #27
love the new roll cage. hopefully someone comeout with something similar...
BKcrawler is offline   Reply With Quote
Old 03-07-2013, 01:24 PM   #28
DISTURBIN' tha PEACE's Avatar
Lookin' good Ryan.
Originally Posted by heinie_21 View Post
no
Correct. Much better for crawling.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 03-07-2013, 03:47 PM   #29
Unbeliveble work on front cage! It seems a stock part!!
Daigoro is offline   Reply With Quote
Old 03-07-2013, 04:19 PM   #30
Too bad this frame addition is not for sale I know I would buy one
Mr Hyde is offline   Reply With Quote
Old 03-07-2013, 11:34 PM   #31
thanks! still got alot more work to do...
no very far away
no
that is correct, thank you for clearing that up.
thanks man! ive seen a few diffrent set ups on rcc
Originally Posted by DISTURBIN' tha PEACE View Post
Lookin' good Ryan.
thanks sheldon!
thanks! she fits like an OEM part haha
someone is gonna do it soon... ive had a good number of request to make these for people but atm im not.
Old 03-07-2013, 11:48 PM   #32
sorry about the video link guys... heres the link http://s62.beta.photobucket.com/user...E28A9.mp4.html
Old 03-08-2013, 12:19 AM   #33
Ok here's my latest update with the 1.9 gearhead hammer wheels I just bought. The stock off set was not working out the tires were rubbing the inner steering links, so I decided to make spacers out of washers that will look like rotors. I'm gonna post up pics step by step how they were done.
I started off with 2 washers with 1/2 inner holes and some blue painters tape.
I used the tape to cent the washer around the stock hub.
Make sure it fits snug
Locked down in the vice, now push the wash down and cut the extra tape off
It should look just like this.
Now put the hub back on to the rim with the washer and mark all 6 holes with a marker.
Now remove the washer from the hub and Center punch every hole
Vice the washer and dill it out.
Test for all the holes to the stock hub
If all your hole are straight then you can cut to make slotted rotors or just sand in a 45 angle
Note that your screws will need to be almost twice as long. Hope you peps like it.
Old 03-08-2013, 01:35 AM   #34
GREAT solution!!
Old 03-08-2013, 03:14 AM   #35
GREAT solution!!
thanks!
Old 03-08-2013, 10:57 AM   #36
Looks great, nice solution!
Just2Much19 is offline   Reply With Quote
Old 03-08-2013, 04:26 PM   #37
Thanks!
Old 03-08-2013, 04:48 PM   #38
Old guy
ROCKEDUP RICKY's Avatar
I just read all this, Great work.
Did I miss it, but where's the video of this crawling.
ROCKEDUP RICKY is offline   Reply With Quote
Old 03-08-2013, 05:24 PM   #39
Thanks man! You didn't miss any videos crawling yet haha I need to find a nice spot to crawl soon to shoot a small video. The only video I posted so far was winching up the tool box. Thanks again.
Old 03-09-2013, 12:11 PM   #40
got window mesh ? Haha
Funny that the twin hammers has 4 screw holes around the window, 2 on top and 2 on the bottem, it works perfect to hold in the mesh screen.
I shave down the rear shock mounts so they are not so bulky looking lol and reinforced the mounts with a cross brace.
Made new sway bar mounts and spaced they away from the lower links for better clearance.
Got some wheel screws in today I was just messing around with them haha I'm debaiting if I should do all the wheels? What do you guys think?
Hawaiian hammah time - Similar Threads
hawaiian hawaiian Chit Chat 5 12-24-2007 01:06 AM
One Nada Local boy. Hawaiian Hawaiian kailuaboy Tamiya Txt-1 and Juggernaut 12 12-17-2006 08:04 PM
