Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Hawaiian hammah time
Old 03-01-2013, 10:57 AM   #1
Talking Hawaiian hammah time
Wasup guys here's my vaterrable from Hawaii
As we all know are we all never leave the trucks stock... Lol so I had an old (proline) C10 body laying around that was used on my wheelie king that I chopped up. I also tossed on some integy light buckets and custom a wire harness with resistors to run off 3S.
spitfireat808 is offline   Reply With Quote
Old 03-01-2013, 11:02 AM   #2
Default Re: Hawaiian hammah time
Here's a small mod... I took the original battery/ESC banana connectors and chopped them off so you can replace the crappy ones on your stock motor.
Old 03-01-2013, 11:11 AM   #3
After a few runs I've noticed that this vaterra was very capable of crawling but it needed to be geared down.
I removed the stock spur and noticed that the main shaft hole is fkn tiny! Well after searching around I found this from Losi.
This Losi gear I found at a local hobby shop just plugs right in.
Old 03-01-2013, 11:43 AM   #4
That's quite a jump on the spur. how does she handle with that gear reduction? I was thinking of going that route to go more towards crawl.... Has it completely nerfed your top end?
neverenuffrox is offline   Reply With Quote
Old 03-01-2013, 12:30 PM   #5
06 Super National Champ
JasonInAugusta's Avatar
You're holding out, Ryan.
JasonInAugusta is offline   Reply With Quote
Old 03-01-2013, 12:38 PM   #6
Looks good. thanks for the info on the gear...Doc
Doc Harley is offline   Reply With Quote
Old 03-01-2013, 04:33 PM   #7
DISTURBIN' tha PEACE's Avatar
I swapped mine to 86/22. It does take away a lot of top speed, but if we really wanted that we'd get SC's. We want crawlers. I run the Roc412 3100kv & top speed is not bad still.
What could it be?
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 03-01-2013, 05:28 PM   #8
[QUOTE="DISTURBIN' tha PEACE;4207786"]I swapped mine to 86/22. It does take away a lot of top speed, but if we really wanted that we'd get SC's. We want crawlers. I run the Roc412 3100kv & top speed is not bad still.
Agreed. I just like having a versatile rig. Already have other crawlers coming out my ears.
Old 03-01-2013, 06:31 PM   #9
what does the writing on the body mean, my wife was just in hawaii visiting her family and she said she saw a much of people near the north shore driving their rc trucks at a truck.
l36pontiac is offline   Reply With Quote
Old 03-03-2013, 04:16 PM   #10
Haha just a small jump ;) I changed the pinion down to 26T but I need to drop it down maybe 23T. It still has way to much speed HAHA stay tuned for the power plant pics.
Old 03-03-2013, 04:18 PM   #11
Old 03-03-2013, 04:21 PM   #12
The writing is Hawaiian (puulupiopou) is are Ulua (gt) fishing club name. Puulupiopou = group of pole bendaz
Old 03-03-2013, 04:50 PM   #13
So here's a few pics of my wraith drive shaft mod and custom upper links
Just keep in mind that on the wraith MIP drive shafts you need to shave a little off the ends
The clearance front the drive shaft and the truck tub is perfect!!
Moving on lol I can't stand the front suspension on the vaterrable!
So.... I took it all out haha
I ended up brazing up the front end.
Slash power strokes were way to FAT. I replaced them with king 90mm shocks
I started making a rear shock mount that pushes the shock out so they don't got so much gansta lean on them hahahaha
Chop chop chop! The rear end was getting stock every where so I chopped off about an inch, moved the tire mount up and drilled the frame.
Kings mounted front and rear. 110mm king in the rear with a droop bushing limiter/70w oil, fronts are king 90mm with 70w oil.
Old 03-03-2013, 05:35 PM   #14
Here's a pic from the inside of the cage where I chopped, drilled and added spacers.
Power plant
CC BEC, MMP, TEKIN PRO4.
Old 03-03-2013, 06:01 PM   #15
Thanks for the help on FB.
Looks awesome. Will get to the rear shock mount this week.
shwng1973 is offline   Reply With Quote
Old 03-03-2013, 06:44 PM   #16
hey man no problem! anytime. i still need to shave my rear shock mounts down and clean them up...
Old 03-03-2013, 06:53 PM   #17
Now we're talkin! You think about producing and selling that shock mount system for the front end? I'd buy one.
Soulo747 is offline   Reply With Quote
Old 03-03-2013, 06:55 PM   #18
How are your front shocks working out. That was the first thing I did and I didn't like how it cycles, The lower shock is out too far out on the arm. I'm looking at making a mount farther in on the arm. so for right now I'm back to stock.
The Doc is offline   Reply With Quote
Old 03-03-2013, 07:16 PM   #19
id like to make more and sale them but they take a LOT of time to make -____-"
Old 03-03-2013, 07:22 PM   #20
I love the way the front end articulates now, much much more free and the front doesn't feel so dead no more. The power stroke shock didn't work so well but when I tossed in the dual rate shocks there was a big difference.
Hawaiian hammah time - Similar Threads
hawaiian hawaiian Chit Chat 5 12-24-2007 01:06 AM
One Nada Local boy. Hawaiian Hawaiian kailuaboy Tamiya Txt-1 and Juggernaut 12 12-17-2006 08:04 PM
