Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Transmission
Old 03-15-2013, 01:32 AM   #1
Default Transmission
Hi guy's
i got a noise coming from my transmission i need to pull apart have a look.
should it have grease in it? can u get steel gears?
Whats the easyest way to slow it down as i do more crawling/rock bashing so i dont need the speed...smaller pinion?
Gammo is offline   Reply With Quote
Old 03-15-2013, 03:31 AM   #2
Default Re: Transmission
Tie it to a brick.
I kid!
Assuming you are just using stock motor you can increase spur size or decrease the pinion (Spur Divided by pinion = gear ratio.) the greater the number the slower it will go "just a guideline."
Play with sizes till you find your speed
Kzzican is offline   Reply With Quote
Old 03-15-2013, 03:58 AM   #3
yeah all stock.....thanks
Old 03-15-2013, 09:26 AM   #4
I took mine apart and it was dry. I like to lube the gears in my trannys. There is no steel gears at the moment besides the top gears in the trans that it comes with. Yes a smaller pinion will slow you down.
lazynocturnal is offline   Reply With Quote
Old 03-15-2013, 10:34 AM   #5
lightly grease the trans gears and just toss 32p gears 56T spur 12T pinion. that should be crawler status with the stock motor.
spitfireat808 is offline   Reply With Quote
Old 03-17-2013, 04:35 AM   #6
Cool il try that.....
Does any spur & pinion fit?
Old 03-17-2013, 05:14 AM   #7
32p is def. the strongest way to go but the stock combo wont stress out a 48p . I ran a 20t pinion and there is room to go to probably 18t. This is SLOOOW.
I got jack of it sliding around on its slippery belly and went back to stock gearing on 3S.
When I want to crawl I get my Wraith out
northkona is offline   Reply With Quote
Old 03-17-2013, 05:24 AM   #8
cool.....but what spur gear fits....axial?
Old 03-17-2013, 06:53 AM   #9
32p Losi 32P Kevlar Spur Gear, 51T (XXX-NT) [LOSA3907] | RC Cars & Trucks - A Main Hobbies
Old 04-20-2013, 02:12 AM   #10
ok i got these 32p gears 51T spur 12T pinion.
But i cant make the motor move over the meet the spur i need about 1mm more.
any one else have this prob or what should i do?
go to a 14T
Old 04-20-2013, 10:04 AM   #11
You need a bigger spur. Maybe a 54 or 56. The bigger the spur the slower it will go.
Savage00 is offline   Reply With Quote
Transmission - Similar Threads
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. Tomy Axles, Trannys, T-case 4 01-20-2013 08:48 AM
Axizl Transmission VS Wheely King Transmission Tonelock HPI Wheely King 13 09-03-2008 01:39 PM
