Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: New Aluminum wheel hex fits but pin is small issue
Old 04-01-2013, 08:46 AM   #1
Default New Aluminum wheel hex fits but pin is small issue
So I replaced my plastic hex's with aluminum for obvious reason, the rims actually snap into these with a small pin AND noticed the hex's came with a bigger pin that DIDNT fit in the TW , SO I used my semi bent smaller ones. Are you guys using these small ones with a brushless setup ( more power) or did u guys upgrade the axle part to a bigger one?
Blinkfan5150 is offline   Reply With Quote
Old 04-01-2013, 08:50 AM   #2
Default Re: New Aluminum wheel hex fits but pin is small issue
I cut up a small allen wrench that fit into the hole. The allen wrench is much better material than the stock pins. I don't know which aluminum hexes you bought, but the Losi clamp on variety is great! They clamp on tight enough to take some stress off the shear pins. I'm not expecting any more problems out of my pins now.
Mnocton is offline   Reply With Quote
Old 04-01-2013, 09:06 AM   #3
Those pins are 1.5 instead of 2.0 like an axial pin.. u don't need to upgrade those if you go brushless. I left mine stock and just added a 2mm set screw.. clamping hex are nice but I'd stick closer to the losi brand....
sent from my Galaxy S3 on Verizon
scottanthony is offline   Reply With Quote
Old 04-01-2013, 09:32 AM   #4
I might have to cut up an Allen wrench if these pins break. Good idea!
Thanks guys
Old 04-01-2013, 10:22 PM   #5
I just drilled out the axles for bigger pins so I could use the axial hexes. Very very easy to do.
vypr is offline   Reply With Quote
Old 04-01-2013, 11:38 PM   #6
I use the losi clampers, and love 'em. Ones from the night crawler, I believe.
neverenuffrox is offline   Reply With Quote
Old 04-02-2013, 08:15 AM   #7
I used a set of losi aluminum lock ons that I got TLH. They were to small ID so I just drilled them out to fit and their awesome! The plus side is they acted as a small spacer giving more wheel clearance.
nomad77 is offline   Reply With Quote
Old 04-04-2013, 09:25 AM   #8
I almost did this, but was worried the pin might rub on the knuckle housing since the stock pin is more or less touching already. Axial pin works without rubbing?
tim the toolman is offline   Reply With Quote
Old 04-10-2013, 07:03 PM   #9
Just an FYI that Hot Racing has some aluminum clamp on hexes designed specifically for the TH. I picked some up at the LHS yesterday and they appear to be pretty nice.
http://www.hobbyetc.com/item.cgi?par...2CzGDxaKzSn5eQ
Hobine is offline   Reply With Quote
Old 04-12-2013, 04:26 PM   #10
Since i had some axial pins and hexes already i decided to go ahead and drill out for the bigger pins. No problems, works great! Only thing was i had to resharpen my little drill bit 3times-those axles must must be made of fairly hard steel
New Aluminum wheel hex fits but pin is small issue - Similar Threads
Switch from hex to pin? Superbeast Axial SCX-10 5 03-03-2013 09:41 AM
rc4wd steelies, pin or hex stanmondz Tires and Wheels 6 01-24-2013 11:52 AM
pin to pin wheel widner johnnyh66 Tires and Wheels 8 06-01-2011 10:25 AM
