Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Dissapointed esc and motor purhase
Old 04-02-2013, 08:25 PM   #1
Default Dissapointed esc and motor purhase
Bought
FUZE 1/10 Sensored 17.5T ESC/MotorCombo
because hobby shop guy said its the perfect brushless system " going to be faster than that HH13T you have without the brushed hassle"
It's hella slow IMO only for crawling
I want to BASH!!!
So bought a tekin sensors gen2 10.5 motor
IS THIS GOING TO BE LIKE THE HH13t or faster?
BTW flashed the ESC to full power and it was still WAYYYYY TOOO SLOW.
Any input would help at this point have t opened up the tekin box yet.
Thanks guys
Blinkfan5150 is offline   Reply With Quote
Old 04-02-2013, 08:34 PM   #2
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Re: Dissapointed esc and motor purhase
10.5 will be quite a bit faster than the 13t from HH.
Harley is offline   Reply With Quote
Old 04-02-2013, 08:37 PM   #3
That's what I wanna hear!!!
Old 04-02-2013, 08:46 PM   #4
20K Club
Harley's Avatar
I personally think that is too fast of a motor for the handling of this rig but maybe with a bunch of tuning it would be OK.
Old 04-02-2013, 08:53 PM   #5
Scale Detail Engineering
Never listen to the hobby shop guy, research it on RCC.
johnnyh66 is offline   Reply With Quote
Old 04-02-2013, 09:30 PM   #6
I like the speed of the brushed HH 13t so I'm going to program the ESC down a bit to match that speed.
Old 04-02-2013, 09:32 PM   #7
It was an impulse buy for sure. His idea of fast wasn't close to mine.
Definately asking you guys next time before hand
Old 04-03-2013, 12:37 AM   #8
Lmao, we have one of those!
Too true..
elsewhere is offline   Reply With Quote
Old 04-03-2013, 01:20 PM   #9
5.5t is where its at ( 7400) kv if you really want to bash and mine handles just fine in grass or dirt just not pavement cause of the tires pinwheelin
bashin calfee is offline   Reply With Quote
Old 04-03-2013, 01:28 PM   #10
had that prob as well, but I put in hpi mini trophy truck lower control arms which were about an inch longer than stock. helped that prob 10 fold.
wlsmoku is offline   Reply With Quote
Old 04-07-2013, 11:36 PM   #11
im runnin a 7700kv castle and mmp. its pretty wicked and has awesome excel, but its easy to lose control. love getting 10-12 ft of air. finally found a weak point in either the rear axle or the locker, havent torn it down yet.
ericsarge is offline   Reply With Quote
Old 04-08-2013, 12:06 AM   #12
Probably one of the plastic axle hexes.
MachtSchnell is offline   Reply With Quote
Old 04-09-2013, 08:04 PM   #13
BINGO. glad thats all it was. broke the dreaded shock tower tonight. next will be making it out of aluminum, sway bar and stiffer, more aggressive tires.
Old 04-17-2013, 03:21 PM   #14
I am thinking of putting a sidewinder sv3 and 4 pole 3800 castle brushless motor in mine. Can anyone comment on this setup?
youthmanrcer is offline   Reply With Quote
Old 04-17-2013, 10:57 PM   #15
im currently running mmp and 17.5T fuze motor.... it sucks! I can hardly crawl with it and its not a high enough rpm... so I just picked up a velenion motor... well see what happens tomarrow! and ill be sure to tell you guys!
mhflies is offline   Reply With Quote
Old 04-18-2013, 01:01 AM   #16
Depends
2s or 3s? Sensored or sensorless?
On stock gearing with 3800 its gonna be really fast. And if it's ran at low crawling speeds at stock gearing the ESC might get hot. Also unless re-geared the slow speed operation will be choppy if a sensorless motor is used.
So far I'm liking the tekin roc 412 3100kV sensored setup I went with... and thanks to Badger for suggesting this setup in his thread. It was an expensive set up but well worth it!!!
Old 04-18-2013, 01:14 AM   #17
Velenion will be good for speed, but it's still sensorless and won't be smooth at low/crawling speeds like a comparable sensored motor would.
Old 04-18-2013, 09:16 AM   #18
Does the roc have pretty good top end as well?
Old 04-18-2013, 11:53 AM   #19
On 2s it seems about the same as stock... but on 3s it's quite a bit faster. From slightly rolling backwards to full forward it can do back flips and land on its wheels
Do note that this setup is no longer "water proof" and necessary precautions would need to be taken if it was going to get substantially wet/submerged. Apparently sensored motors don't like water because of their sensors, but they can be made more water resistant; and that goes for ESCs as well.
Dissapointed esc and motor purhase - Similar Threads
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? THE CRAWLER KING Newbie General 6 08-22-2010 08:10 AM
dissapointed............. KrawlerKing Team Losi Comp Crawler 6 02-05-2010 09:56 AM
single motor esc or dual motor esc jwo Electronics 0 01-21-2010 12:42 AM
A little dissapointed-My first two feet. raypa Axial AX-10 Scorpion 14 08-25-2009 10:24 PM
Dissapointed, Pro-Line 2.2 beadlocks & M2ks crawler_king Tires and Wheels 16 03-10-2008 09:11 PM
