04-11-2013, 10:14 AM | #21 |
| Re: New Blue monkey Front shock mount! |
04-11-2013, 12:51 PM | #22 |
I wanna be Dave Join Date: Sep 2004
| Re: New Blue monkey Front shock mount! 100mm is 4" ;) i misread..... thats my excuses and im sticking to it.
04-11-2013, 02:23 PM | #23 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
Maybe its just me, but something doesn't seem right with the servo mount. Almost like its mounted too far back. Are there any clearance issues with moving it forward and flipping the horn. To level out the steering rod? |
04-11-2013, 05:41 PM | #24 |
Rock Stacker Join Date: Mar 2013 Location: USA
I don't see the point of relocating the stock steering components more forward. The slop comes from the stock rack that has rather loose tolerances. If you put the servo far enough forward than there would be no need for the stock rack.
04-11-2013, 06:31 PM | #25 |
Quarry Creeper Join Date: May 2010 Location: albuquerque
i noticed there was a slight difference in the part shown in post #1 compaired to post #9. the website also shows the part from post #1. i personally like the part from post #9, if i were to order one can it be like the one in post #9? thanks, Rick
04-11-2013, 11:44 PM | #26 | |
Pebble Pounder Join Date: Feb 2013 Location: Ramsey
| Re: New Blue monkey Front shock mount! Quote:
04-11-2013, 11:48 PM | #27 | |
Yes, with it mounted on the plate (horn upside down) it would hit the front diff. Im still playing with different positions of the horn on the servo to decrease the angle. Last edited by Kzzican; 04-12-2013 at 12:43 AM. | |
04-12-2013, 12:12 AM | #28 | |
You would be correct if we were dealing with a solid axle, but its IFS so the rules change. Some type of steering rack is need due to the use of IFS. Much like the geometry between the a-arms, cvds, and camber links; The steering rack is there to keep the distance of the steering linkage at the proper height. When the suspension cycles from full extension to fully compressed the steering linkage is moving in a circular motion (circumference;) at the center of the circle is the pivot point for the linkage. If you move this pivot geometry up the steering will bind and try to push the linkage in the opposite way during full compression; Lower and the same result while trying to decompress. Hope this helps you understand. | |
04-12-2013, 12:22 AM | #29 | |
This is their official thread and you can ask that question and they will answer it. Vaterra Twin Hammers - Suspension Upgrades | |
04-12-2013, 12:27 AM | #30 |
Haha, I didn't look that far into it. I just saw a few pics of direct linkage setups on the VTH and assumed it worked. Since they do move independently from one another bump steer and all kinds of funny stuff would happen if both links mounted to a single point on the servo horn. I like this vertical shock mount for better/smoother articulation, as the stock system has many pivots that inevitably create friction. I also like the ability to run a battery up front, or possibly one up front and one in the back wired in parallel for maximum run times. |
04-22-2013, 12:14 AM | #31 |
Well... Things are a little too tight to to fit a battery up front with this mount (both 4000mAh 2s hardpack, and 3s batteries that fit in the back will not fit). It could be be done, but the cage might need to be modified. The 2000mAh 2s cells fit no problem, but that's no fun. Also, to anyone thinking about running this on the street... DON'T roll the vehicle at speed, which will inevitably happen. I've bent this thing at least three times and had to hammer it back straight, and don't know how many more times it'll be able to reformed before breaking. The thing is that the shock mount sits higher than the line from the roof to the hood; and it will gladly accept impact and deform. It sucks having to pull the whole cage to remove this mount just to straighten it out. Might have to mount the spare tire on the roof or the hood to take the impact so the shock mount doesn't have to. But mounting the tire on the hood will look stupid, and mounting it on the roof will raise the center of gravity and lower its ability to go under obstacles. A tall bumper/brush guard could work, but it would break/bend and become scrap in no time. Last edited by MachtSchnell; 04-22-2013 at 12:19 AM. |
04-22-2013, 06:34 AM | #32 | |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
04-22-2013, 10:38 AM | #33 |
It might help. But all three times mine bent, either side bent back towards the windshield. So that might just cause both sides to twist, or bend backward upon impact.
04-22-2013, 10:49 AM | #34 |
Pebble Pounder Join Date: Mar 2013 Location: Fowler
Dammit I just ordered mine
04-22-2013, 12:54 PM | #35 |
I have crashed mine plenty of times and never had a problem, only minor scratches which are expected. I guess im just lucky since the only issue i have had are just broken hex pins. A support bar would be a easy fix to spread the weight. If you have a suggestion or a fix just post in Blue Monkey Thread and im sure they will take it into consideration. |
04-22-2013, 06:09 PM | #36 |
Quarry Creeper Join Date: Dec 2012 Location: Canada
Is High speed handling better or worse with this? Ie Does it tip over less? |
04-22-2013, 06:21 PM | #37 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
I dont have one (yet) but i imagine it will let the front end work better with some properly adjusted shocks. The bigger gain will be from relocating the battery down lower though
04-22-2013, 07:36 PM | #38 |
Depends where the battery is relocated to. If on the belly pan in place of the servo, esc, and receiver than it would make a huge difference; but would be a total wash after factoring in the amount of time it will take to swap in a fresh cell. I don't think mounting a cell atop the front diff would be any good for speed, because of the loss of traction in the rear. Also with a cell in standard position under full brake the rig is already "endo" happy. On the flip side, running a battery up front should work very well for crawling. |
04-22-2013, 08:17 PM | #39 | |
04-22-2013, 09:43 PM | #40 |
Quarry Creeper Join Date: Oct 2010 Location: denver
Gonna try to put a winch in there. I bent one side then straightened it out ground down a old link and no more bending !!!
New Blue monkey Front shock mount! - Similar Threads | ||||
Chaotic TH Carbon Front Shock Mount | Chaotic Crawlers | Vaterra Twin Hammers | 19 | 10-09-2013 12:35 PM |
Front shock mount question | 1375 | Axial SCX-10 | 5 | 11-01-2012 07:56 AM |
New idea for front upper shock mount on 1/6th Jeep | BigSki | Large Scale Rigs | 2 | 09-15-2012 03:04 PM |
