Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Aluminum 5-Spoke Bead Lock
Old 04-12-2013, 09:31 AM   #1
Default Aluminum 5-Spoke Bead Lock
Found these on Amazon and was wondering if one of the more seasoned enthusiast here have run across these before and if you have thoughts you'd like to share.
Also wondering if these will fit ok on a twin hammers
TopCad Aluminum 5-spoke Bead Lock Wheel (2) Red for Axial Wraith
ntruder is offline   Reply With Quote
Old 04-12-2013, 09:36 AM   #2
Default Re: Aluminum 5-Spoke Bead Lock
That wheel is a 2.2. The hammers is a 1.9 wheel rig. Look at Badgers thread on how a 2.2 wheel and tire look on the TH. Awfully big.
cobrawes is offline   Reply With Quote
Old 04-12-2013, 09:37 AM   #3
Here is a link to the picture.
Badger's Vaterra Twin Hammers 1.9 Rock Racer
Old 04-12-2013, 09:42 AM   #4
thanks for the quick post.. I thought they were 1.9.. thanks for pointing that out. I have read thru some of Badgers post.. and the 2.2 look out of place on the TH. I have some Hitman 1.9 with Rock Crusher II and it does well.. at least until the hub bolts all feel out on one wheel. Gotta remember to check those b4 each run until I can get som elock tight on theose little suckers. I'm looking for something in red. I have the Axial 8 hole bead locks with Crazy Crawlers mounted on them.... works well.
Aluminum 5-Spoke Bead Lock - Similar Threads
NewAge Aluminum Bead Lock Wheel Alex.G Venom Creeper 15 10-20-2010 08:08 AM
rc4wd aluminum bead lock wheels 01XJ Newbie General 3 06-22-2006 07:38 AM
Aluminum 40 Series Bead Lock DrasticSports Tires and Wheels 6 05-06-2006 03:17 PM
