Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Hitec 225MG servo horn
Old 04-13-2013, 06:47 PM   #1
Default Hitec 225MG servo horn
I got a 225MG to replace my stock shift servo, but I guess the horn size/tooth count is different. Anybody suggest what to get to replace it with?
cby7715 is offline   Reply With Quote
Old 04-13-2013, 07:16 PM   #2
Default Re: Hitec 225MG servo horn
I purchased a Hitec HS-645MG, and had the same issue. There was a small plastic bag of parts that came with my Twin Hammers, and it contained the correct spline adapter for the Hitec servo. Hope this helps.
AlphaOne is offline   Reply With Quote
Old 04-13-2013, 10:28 PM   #3
i used a team associaed sc10 steering servo horn with hitec spline count. then made new shift linkage using 2 short axial rodends. it worked perfect
stick-boy-rick is offline   Reply With Quote
Old 04-14-2013, 09:21 AM   #4
OK. Sounds like I'll have to just make one! Thanks
Hitec 225MG servo horn - Similar Threads
Hitec HS-225MG servo? petokang Losi Mini-Rock Crawler 6 07-09-2011 02:42 PM
Servo stretcher and Hitec 225mg torque monkey Axial AX-10 Scorpion 10 12-05-2008 03:57 PM
