Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: front axles coming out
Old 04-14-2013, 04:06 PM   #1
Default front axles coming out
my frontleft axle keeps slipping out of the differential... any ideas on what could cause this or any tips to help prevent it in the future would be greatly appreciated
texguy is offline   Reply With Quote
Old 04-14-2013, 04:45 PM   #2
Too much down travel on the A-arm. Mine used to pop 'em out like crazy... I internally limited my shock travel with a sliver of nitro fuel tubing around the shock shaft, under the piston. Solved the problem!
neverenuffrox is offline   Reply With Quote
Old 04-15-2013, 01:29 PM   #3
Default Re: front axles coming out
yeah, that sounds about right.... it seems to happen after a rollover always...
front axles coming out - Similar Threads
No need for a Feeler, Rear Axles Coming soon! RcBro Axial Wraith 23 06-10-2012 07:10 PM
front shaft coming off? Ryan33 Axial AX-10 Scorpion 11 11-25-2008 01:41 PM
TLt axles coming back? gr33nlemon General Crawlers 17 10-12-2008 09:15 AM
Front axle C's screws keep coming loose Jus Axial AX-10 Scorpion 8 07-09-2008 07:10 PM
