Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: VP Rigid light bar question
Old 05-03-2013, 01:03 AM   #1
Default VP Rigid light bar question
OK I have a question about wiring an LED light bar. I picked up a VP Rigid light bar. This light is meant to run off of a 3s Lipo. The electronics on my Twin Hammers is stock so I am only running 2s. The question is I have a battery similar in size to the Hammers battery and it is 3s. Can i run the light straight off of this batter or will this cause damage? i know I could wire in an on/off switch but for now is it ok to power it off of its own dedicated battery?
sgtlopez79 is offline   Reply With Quote
Old 05-03-2013, 02:06 AM   #2
Smile Re: VP Rigid light bar question
The VP light is meant to run off the power supply. ( the battery) not the receiver. You can hook it directly to your 3s battery or use a y adapter and run it off your 2s. It's a heck of a lot brighter on 3s 11.1v.
RustenPaines is offline   Reply With Quote
Old 05-03-2013, 01:18 PM   #3
Default Re: VP Rigid light bar question
Thanks for the reply. I tried it off of both battery types and it's WAY brighter off of the 3s.
Old 05-04-2013, 10:17 AM   #4
you can run it on a stand alone 3s battery..i run mine off a 450-800mah battery..small enough to fit under/behind cockpit cover.
ROLANDROCKSHOP is offline   Reply With Quote
VP Rigid light bar question - Similar Threads
Rigid industries LED light bar from VP Mike McLeod Axial SCX-10 3 12-27-2012 02:33 AM
Axial 5-light universal light bar wiring question... KillerBlackbird Axial Wraith 9 11-28-2012 07:18 PM
Emergancy light bar question braceysdad Chit Chat 3 03-16-2009 10:35 PM
