![]() | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Tucson
Tried to get away from the traditional stock body panels with the metallic gray paint and green strip that runs along the side. I fabricated my own stainless steel body panels. Done so far: - Stainless steel body panels - Mamba Max Pro ESC w/cheap 17.5T brushless - Tonight (5/6/13) will be adding Holmes Hobbies TorqueMaster 13T Expert motor - MG200 front shock modification with Axial 90mm shocks w/40WT oil - 60WT oil in rear shocks - 1.55 RC4WD iRoks tires / 1.9 Pitbull tires (depends on what I feel like running) - Savox steering servo - Moved steering servo to replace shift servo More to come soon... ![]() ![]() ![]() ![]() Here video in slow motion. It's kind of long, about 9 minutes. Enjoy! |
![]() | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
We need to get these out again, mines almost back together. Just have to finish up wiring in winch/lights
![]() | #3 |
![]() | #4 |
Added a new Holmes Hobbies Torquemaster 13T and added a heat-sink with fan just for safe measure. Will hopefully be able to get her out this weekend to test her out. Also added the Losi Kevlar 51 tooth 32 pitch spur gear (perfect match for slipper pads) and a 15 tooth pinion. ![]() ![]() Last edited by Savage00; 05-07-2013 at 05:45 PM. |
![]() | #5 |
Rock Stacker ![]() Join Date: Mar 2013 Location: Gainesville
nice TW you have there.. the tires you are running... 1.55 RC4WD iRoks tires .. what are those mounted on?? .. I have the 1.9 iRoks on Axial 8hole beadlocks.. the tire is awesome and have great grip... but to me they make my hammer look cartoonish with the tall tires... |
![]() | #6 |
one other question.. that roof with the LED's is just wicked looking.. is that a mod you did youself, or did you buy that some place and then mod it... which ever.. I want one.. |
![]() | #7 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
The roof is a dinky rc product. I have one also. Cant tell you which led's they are though.
![]() | #8 | |
| ![]() Quote:
thanks for the info.. found them just b4 i read this reply. The LEDs they have are a tape strip that was cheap enough to give a try. The LEDs that Savage00 has on his are much better looking. | |
![]() | #9 |
![]() | #10 | |
| ![]() Quote:
Yes, the roof is the Dinky RC roof. The LED strip that comes with it broke 30 seconds after I took it out of the package. The wires that come out of the strip are not secured very well, if you try to manipulate the wires at a sharp bend close to the base of the strip you can tear the solder joint along with the copper trace right out of the LED strip. So what I did was purchase two of CrawlerDad's 2" LED light bars and mounted them inside the Dinky RC roof, then very carefully with a Dremel cut out the openings for the light to come through. The only thing I don't like about Dinky RC roof is the it has a high profile and if you roll your rig the roof light housing gets the brunt of the impact and gets boogered up really bad. It will start to look terrible real quick. It also gets hung up on rocks if you wedge between boulders. Besides those issues it looks awesome in my opinion. As for the 1.55 wheels, they're RC4WD Stamped Steel beadlocks. Last edited by Savage00; 05-09-2013 at 01:49 AM. | |
![]() | #11 |
Quarry Creeper Join Date: Feb 2013 Location: prather
I was thinking of using that cooling fan/heat sink. glad to know it fits.
![]() | #12 | |
| ![]() Quote:
Thanks for the info on the LED's.. might have to oder a set.. I ordered 2 roofs yesterday.. should be here in a couple of days... ![]() Question about the roof... does the roof light housing stand taller that the stock roof with the light buckets? I'm not too worreid about getting hung up on boulders.. I'm more into hill climbing, trail riding and some light yard bashing. | |
![]() | #13 |
I would say It doesn't stick up any further than the stock roof. As far as the way it looks, it is my personal favorite looking roof so far.
![]() | #14 | |
| ![]() Quote:
![]() | #15 | |
| ![]() Quote:
![]() | #16 |
Nice looking TH, cool vid. Like the music, who is that?
![]() | #17 |
Rock Crawler Join Date: Oct 2010 Location: Reno
I'm running a Novak 17.5 on 3s. How do you like your truck with the 13t HH vs a brushless system?
wlsmoku's twinny twin | wlsmoku | Vaterra Twin Hammers | 26 | 06-05-2013 04:01 AM |
Twin Hammers in Twin Cities? | 89XJ | Minnesota | 7 | 05-06-2013 02:59 PM |
twin hammers | khoods | Newbie General | 11 | 04-22-2013 05:44 PM |
Twin Hammers are in!!! | tunnalram | North Dakota | 0 | 02-11-2013 04:08 PM |
