Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Shock and Spring upgrades
Old 05-27-2013, 08:29 PM   #21
Default Re: Shock and Spring upgrades
Stock is right on 108mm
Powerstrokes are around 104mm
CREEPINKING is offline   Reply With Quote
Old 05-27-2013, 09:14 PM   #22
Originally Posted by Blinkfan5150 View Post
I use the 110mm piggyback kings in the rear I can't imagine going any smaller. Need all the clearance you can manage sometimes. Only problem is the super soft spring. Any other brand make stiffer springs for these dual spring kings?
That's too bad about the spring......I was looking into those as well......
wlsmoku is offline   Reply With Quote
Old 05-27-2013, 10:24 PM   #23
Originally Posted by wlsmoku View Post
I read the same thing, but I put calipers on my stockers and only got 108mm. I am thinking that going a little longer and making a bracket off the stock mount to adjust for the longer shock would be ideal
Not that I don't believe you but I just put calipers on mine and your right, 108mm center to center, fully extended. I agree with BlinkFan, I really wouldn't want to go any shorter. 110mm seems to be the closest match. But the lack of spring rate availability will keep me from buying the Kings(RC4WD). Even though they look badass!
Maybe Powerstrokes are the best bet. But 118mm sounds like too much.
Can one of you guys put calipers on a Slash GTR rear shock if you have them laying around? IMO they'd be ideal due to the spring options available and also the MIP bypass setup.
LGrocks is offline   Reply With Quote
Old 05-27-2013, 10:30 PM   #24
Dang, missed that for my last post... The Powerstrokes are 104mm.
Creepinking you say they work great? So no issue with 4 mm less travel?
Note: Sorry Photon, not trying to hijack your thread. Just digging up info with you, not against you.
Old 05-27-2013, 10:39 PM   #25
No where close to binding or bottoming out. I wouldnt go much shorter though. The 103mm G-mades would still work.
Keeping the CG low and still offering the full range of travel is why I went with the Powerstrokes.
Old 05-28-2013, 10:22 AM   #26
Are we talking about the same Power Strokes?
Pro-Line PowerStroke Shocks Slash Rear (118mm)
This number seems out of line.... Pro Line's site gave no length values that I could find.
Will the shock extend farther if uninstalled?
photon_trap is offline   Reply With Quote
Old 05-28-2013, 10:28 AM   #27
Naa this is all good info we needs to be knowin' Thanks
It's confusing because there seem to be so many differing numbers coming from all over. A clearer picture is emerging though
Old 05-28-2013, 11:55 AM   #28
Why not just run spacers in some shocks that are too long or look for longer rod-ends for some that are too short? You aren't really loosing 4mm of travel with a 4mm shorter rear shock. If the stroke is longer you can actually gain travel.But if the collapsed or extended length are different that's where you have to do some adjusting.
The problem is no manufacturer lists stroke.
I'm looking into a set of AE shocks for my hammer. I like the way they are built, there are a million springs/pistons available, and I can make pretty much any stroke/length I want with various shafts and body lengths.
terrible is offline   Reply With Quote
Old 05-28-2013, 11:56 AM   #29
And the price on the proline power strokes are rediculous. And I have never found shafts for them anywhere when one does wear out or break.
Old 05-28-2013, 12:58 PM   #30
Although their site isn't working for me right now I saw the same Pwrstrokes on another site. They are listed in title as 118mm like the link you listed. But in the description it says length is 104mm. Who knows maybe 118 is overall length??
Old 05-28-2013, 01:04 PM   #31
Good points. Which AE shocks are you looking at?
Old 05-28-2013, 01:15 PM   #32
Every one is selling new take-off b4.1, t4.1, and b44.1 shocks. Not sure what length to go with but between those three cars/trucks and with older shafts still for sale there has got to be something that could be made to work properly.
I know the b44.1 has rather short front shocks. I belive the shaft was some where around .80" long.
And all the bodies are threaded and hard ano.
Also the touring shocks used to use the same shafts/seals/bodies.
Shock and Spring upgrades - Similar Threads
Shock upgrades glafko Axial AX10 2nd-gen 2 04-07-2013 06:55 PM
Shock oil and shock spring help entropy General Crawlers 10 01-29-2011 09:40 AM
ax10 shock upgrades slowlearner Newbie General 1 01-25-2010 09:38 PM
SCX-10 Shock Upgrades 69CrazyHorse 2.2 Scale Rigs 1 03-13-2009 09:07 PM
