Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: better steering rack?
Old 06-07-2013, 11:47 PM   #61
Default Re: better steering rack?
Dido
xCoolHandLukex is offline   Reply With Quote
Old 06-08-2013, 03:54 PM   #62
Just an update for those of you who are do it yourselfers, or just cheap like me. I've got 8 packs through the homemade bell crank set up so far without any issues. It works so much better than stock. I swapped out the extra tie rod i was using as a brace with the original steering rack. I milled it down a bit for clearance. I used the stock bearings that were in the rocker arms above and below the "bell cranks". There is no binding or slop in the steering at all now. Only negative is that I think there's a bit more bump steer, but honestly, I never checked the original design. As you can see, fitting either a rocker shock setup or outbound is no problem.
Hobine is offline   Reply With Quote
Old 06-08-2013, 06:59 PM   #63
***Derwood Designs Double D steering kit for Twin Hammers***
Kits are up for sale with all the details. Doing a preorder sale for the first 30. Follow the link to pick up yours
derwood21 is offline   Reply With Quote
Old 06-08-2013, 07:52 PM   #64
I find it beautiful in it's simplicity.
photon_trap is offline   Reply With Quote
Old 06-08-2013, 08:41 PM   #65
PM sent
tim the toolman is offline   Reply With Quote
Old 06-08-2013, 08:55 PM   #66
Also thought I'd say me and a buddy had a great day of crawlin today with our twammers. I was really starting to like these little cars, started to realize they were doing a lot of lines with less difficulty than my honcho which is set up pretty good. Biggest issue we had was probably the steering. Mine started out sloppy and now is a lot sloppier. I was starting to have binding issues, even with my s197 servo. His was binding even worse, may have been why his cs 170 died and he had to change to his spare servo. So Derwood thanks for offering a badly needed product
Old 06-08-2013, 09:10 PM   #67
PM sent. Thank you
COORZ is offline   Reply With Quote
Old 06-11-2013, 10:29 AM   #68
PM sent.... thank you!!!
ntruder is offline   Reply With Quote
better steering rack? - Similar Threads
GPM Steering Rack Upgrade? alexchen86 Tamiya XC/CC01 5 01-07-2013 08:13 PM
rack and pinion steering? bluelightning General Crawlers 6 07-17-2008 01:59 AM
