Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: help
Old 06-01-2013, 01:06 AM   #1
Default help
hi guys my TH is standard wants the easyest way to slow it down for crawling
Gammo is offline   Reply With Quote
Old 06-01-2013, 06:00 AM   #2
Default Re: help
Easiest would be a larger spur and smaller pinion. Other option would be a higher turn motor.
rustykaos is offline   Reply With Quote
Old 06-01-2013, 07:06 AM   #3
Default Re: help
id go 21t motor..
still has a bit of pep in 2nd gear while still able to do some crawling in 1st.
my 2 cents.
ROLANDROCKSHOP is offline   Reply With Quote
Old 06-01-2013, 10:46 AM   #4
Default Re: help
We dropped a stock motor setup down to a 20t pinion, and it's WAY better for crawling. Another $5 idea.
Generis is offline   Reply With Quote
Old 06-01-2013, 07:00 PM   #5
Default Re: help
I'm running a 19t it's the smallest that I could fit and still have it catch the spur.
xCoolHandLukex is offline   Reply With Quote
Old 06-02-2013, 06:58 PM   #6
Default Re: help
i'm running stock spur with a 19 tooth pinion and a 55t axial motor total of $20 and its crawls great now
401cj is offline   Reply With Quote
