Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Rear Sway Bar Rant
Old 06-16-2013, 10:55 AM   #1
Default Rear Sway Bar Rant
I installed the rear sway bar, only to find out that it hits the battery tray. I am using 4000Mah battery, so trimming the tray in not an option, as it will still hit the battery.
Why is horizon selling $15 sway bar that is clearly not compatible with the car? Is it common practice in RC hobby to "fix" the hop ups? Searched the forums and there seems to be no fix for this issue.
For now I am thinking of removing the bar, as it limits the suspension travel and hits the battery all the time.
BatteryPowered is offline   Reply With Quote
Old 06-16-2013, 12:54 PM   #2
Default Re: Rear Sway Bar Rant
I trimmed mine to clear the tray as I'm running my batteries length wise. I have read on here that some peeps are bending their sways towards the shock to make it wider and clear the battery tray. In the years I have been into rock crawling, I have seen that not all upgrades are simple bolt on and go. Some require mods and tweaks to get them to work.
My favorite is when you buy a item that has a bunch of parts in the bag with no instructions on how to install...
lazynocturnal is offline   Reply With Quote
Old 06-16-2013, 02:30 PM   #3
i had the same problem. although, i am running the stock battery in the stock position, so i just busted out the dremmel and trimmed it down.
desertmaxx is offline   Reply With Quote
Old 06-16-2013, 03:03 PM   #4
Pullman Crawler
A_Jeeper's Avatar
Yeah I thought that was really dumb when I bolted mine up to. I set on linemen's pliers fixed that right up thought.
A_Jeeper is offline   Reply With Quote
Old 06-16-2013, 04:15 PM   #5
I hate the way it's bolted to the arm. I'd rather see it bolted onto the rear of the frame and be mounted into the center of the trailing arms to keep the arms from twisting under flex. But dang it makes a huge difference no matter how it's bolted on!
terrible is offline   Reply With Quote
Old 06-16-2013, 10:58 PM   #6
I just put some little orings on each side of the lower shock mount, it keeps the trailing arms from flopping around
tim the toolman is offline   Reply With Quote
Old 06-18-2013, 08:45 AM   #7
try trimming the ball cups to make them shorter, making the grub screw doesn't bottum out. bend the wire as needed to move freely.
skid is offline   Reply With Quote
Rear Sway Bar Rant - Similar Threads
Rear Sway Bar Lets Crawl Vaterra Twin Hammers 2 03-01-2013 09:39 PM
LTB rear sway bar kit Kzzican Vaterra Twin Hammers 5 02-20-2013 10:41 PM
Rear mounted sway bar. oneeye Vaterra Twin Hammers 3 02-19-2013 07:00 AM
