Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Wheelbyte's Twin Hammers
Old 04-01-2014, 05:33 PM   #41
Default Wheelbyte's Twin Hammers
Hard to tell but the OD looks a lil bigger , shaft looks very similar tho .... Someone has got to own these things , any help someone haha ...... I really just wanna see a pic of the piston to see if they changed design !
Daddy is offline   Reply With Quote
Old 04-06-2014, 02:16 AM   #42
Default Re: Wheelbyte's Twin Hammers
Omg omg omg I found it I found the hammer that inspired my build
moparmagic94 is offline   Reply With Quote
Old 04-08-2014, 04:08 AM   #43
How did you cut that hole for the front shocks?
Old 04-08-2014, 08:54 AM   #44
I received a set of the short course 110mm shocks yesterday and they as larger in diameter an use a Piston and Bladder. Very similar to proline shocks.
mnickolson is offline   Reply With Quote
Old 04-08-2014, 09:36 AM   #45
hummmm that roof looks familiar.....looks just like the one i posted of my TH on facebook hahaha
it looks good dude!
LS1Armyboy is offline   Reply With Quote
Old 04-08-2014, 09:55 AM   #46
Well that's good news for me , bad news for my wife haha... Now I want those for my honcho !
Thx man
Old 04-08-2014, 10:00 AM   #47
Drilled a couple start holes and used an airsaw to cut the rest.
wheelbyte is offline   Reply With Quote
Old 04-08-2014, 11:06 AM   #48
Here is the rebuild kit for the short course.
Thinking of using a pair for the rear but one with out the springs, fill with oil and drill more holes in pistion. Also wish I had a way to turn down the case enough to get rid of the threads.
Old 04-09-2014, 01:37 PM   #49
Hey, how can I purchase that front mount
Old 04-09-2014, 03:57 PM   #50
Combo#2 from the link below is what you need if you plan on leaving your servo in the stock location. derwood21 is the guy who makes them you can PM him for more info.
http://www.rccrawler.com/forum/chass...ml#post4499283
Old 04-10-2014, 12:30 AM   #51
Thank you wheelbyte
Old 04-11-2014, 03:50 PM   #52
Haven't heard from Derwood yet, I wish I'd get an answer kinda need it for my custom build
Old 04-11-2014, 06:05 PM   #53
LukeKang77's Avatar
This might answer your question. Read the bottom of page 3.
***Derwood Designs Double D steering kit for Twin Hammers***
Nice build Wheelbyte! That a good looking Twin Hammer!
LukeKang77 is offline   Reply With Quote
Old 04-11-2014, 10:17 PM   #54
You could also take a look at IRIE Products page. He is also making some. Big difference is that his uses bearing not bushings.
Old 04-11-2014, 11:44 PM   #55
I was also looking at the IRIE bellcrank wondering if I could mount the Derwood shock tower to his top plate. As I really like the looks of the Derwood tower and so far his bellcrank has been pretty good but time will tell how the bushings hold up.
@ mnickolson do you know if two of the short course King shocks will fit next to each other in the lower control arms being they are larger in diameter?
Old 04-12-2014, 03:46 AM   #56
I'm only interested in Derwood's design, it's exactly what I'm looking for in my build gives it a unique look.
Old 04-12-2014, 07:30 AM   #57
wheelbyte to answer your question not on the VP lowers. They are just to big and even on the BMRC shock mount they are to close.
Old 04-12-2014, 05:40 PM   #58
That's what I was thinking thanks for the photos! I think a short course and possibly a ultra scale shock might fit side by side. It also looks like the bottom shock end on the SC Kings is thinner than the piggyback ones which might help with them hitting on the lower arms which is common. How are you going to run the Kings on your TH?
Old 04-12-2014, 08:02 PM   #59
Rigth now I am thinking of try'n 2 pair or the scale ones on the rear and a set of sc on the front. The scale one I have stink on the front but I have talked to a guy running 2 sets on the rear and he says they work fine.
Old 04-16-2014, 12:08 PM   #60
So I got out a bit this past weekend and scouted out a new spot to run.... its in a county park near my house. Endless lines a really fun place.
Wheelbyte's Twin Hammers - Similar Threads
Yet Another Twin Hammers Tin Soldier Vaterra Twin Hammers 12 02-19-2014 07:47 AM
Savage00's Twinny Twin Twin Hammers Savage00 Vaterra Twin Hammers 16 09-19-2013 08:09 PM
Twin Hammers in Twin Cities? 89XJ Minnesota 7 05-06-2013 02:59 PM
