![]() | #81 | |
Pebble Pounder Join Date: Jun 2013 Location: Morgan Hill
| ![]() Quote:
Yeah I was thinking that too when I was installing it. Would not be very hard to drill them out on the tower! | |
![]() | #82 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Fantastic TH build, I may even purchase one now that I have read your thread. Thanxs!
![]() | #83 |
So I competed in a TTC with my TH this weekend out at Hollister Hills SVRA.... this is the same location where 4 Wheeler Magazine holds it's annual the 1:1 Top Truck Challenge. There were 8 events: 1. Log Chain Pull 2. Side by side pit race 3. Water truck pull 4. Hill Climb 5. Obstacle Course 6. Mini Rubicon 7. Tank Trap 8. Mud Pit I did pretty good..... the event was open to both 2.2's & 1.9 scale trucks and the class was mixed. I was the only TH competing, mostly Wraiths or SCX10's. The events were pretty brutal on your rigs I would say by the 7th event a 1/4 of the trucks were out due to breakage. It was tons of fun!!! Anyways here are some photos.... ![]() Hill Climb ![]() Tank Trap ![]() Mud Pit ![]() Here is my rig after......had to do a complete tear down to clean ![]() I also wanted to add that I have been running some of Irie's prototype axles for the TH and they work great!!! Check out the link above to get the full scoop on them. I have also installed the Vaterra HD outdrives. ![]() |
![]() | #84 |
So after the last TTC the stock black oxide hardare on my rims began to rust so I decided to replace with some zinc plated scale hex hardware from Locked UP RC. ![]() ![]() |
![]() | #85 |
Rock Crawler Join Date: Oct 2010 Location: Reno
Do you have plans to come to either of the G6s in August. Brooks Trout 8-9 or Taquito Grandito 8-30. I'm hoping to make it up to both. Would love to see another th guy. It is usually just may son and I running the THs.
![]() | #86 | |
| ![]() Quote:
I can't make Brooks Trout but I'm hoping to make it up to Taquito Grandito on 8/30. It would be cool to meet up with another TH driver for sure..... I'll be sure to keep an eye out for you and your son! | |
![]() | #87 |
I'll keep an eye open for you.
![]() | #88 |
Newbie Join Date: Apr 2014 Location: sac
how did your hammer do in the mud?
![]() | #89 |
![]() | #90 |
The other day while running the screw on the stock motor mount let loose it ended up taking out my HR Al spur. ![]() Since I was going to have to dig into the trans a bit to replace the spur gear I decided to pickup the HR motor mount and motor plate, I also had been sitting on the HR metal gears for the trans so I decided it would be a good time overhaul the transmission. I also went with the Robinson Racing hardened steel spur gear this go around. Hot Racing Motor mount and Motor Plate ![]() Hot Racing Hardened steel gears... lubed with Redline synthetic. ![]() Rebuilt trans with Robinson Racing Hardened Spur. ![]() I also picked up a set of the 1.9 Pitbull Growlers....I knew they were going to be bigger than the Mickey Thompson 4.19 Baja Claws I have been running but I thought I would check them out and see how they looked. I only mounted 1 up on the stock rim just to give me an idea and check for rubbing etc.... ![]() ![]() Not sure if I am totally sold on the bigger tires... I really like the Growlers tread pattern and have heard nothing but great things about the Pitbulls but I think it throws off the scale look a bit. I have heard of people stretching 1.55 tires on to 1.9 rims. I am thinking of maybe doing that with a set of the 1.55 Growlers. Does anyone have any experience with that? Is it a PITA to get the beads to mount? |
![]() | #91 | |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
| ![]() Quote:
![]() | #92 |
Pebble Pounder ![]() Join Date: Jul 2013 Location: Central Rockies
Thanks for posting up a picture of those growlers on your hammer! I have been on the fence about buying a set of those tires for a while now. Yeah they might be to wide for my tastes. Love the tread pattern as well but I think I'm going to try a set of mad beasts instead! They are not as tall and narrower too! Your new wheel hardware looks good man! ![]() |
![]() | #93 | ||
| ![]() Quote:
I looked at the Mad Beasts and they are cool looking tires but I really love the tread pattern of the Growler. I just placed an order for some 1.55's Growlers and I am going to stretch them onto the 1.9 Gearhead Sixers and see how it goes. I have seen some stretched 1.55's and I think they will be in the 4.19-4.25 range which I think fits the scale bill nicely on the TH. I plan on running the Crawler Innovations 1.9 Deuces Wild 4.19-4.25 closed cell foams with them.... I am hoping they fit ok. I'll post up some pics once I get them on my rig. | ||
![]() | #94 |
So I got the 1.55 Pitbull Growlers in and mounted on my 1.9 Gearhead Sixer rims..... The 1.55 Growlers are much smaller than the 1.9 height wise Here is a pic comparing 3 tires...... RC4WD 4.19 Mickey Thomposin Baja Claws TTC 1.55 Pitbull Growlers Stretch onto 1.9's 1.9 Pitbull Growlers Here is a shot of the width of the 1.55 Growler |
![]() | #95 |
Pebble Pounder Join Date: Sep 2009 Location: Heart of the Alps
Loooking scale!
![]() | #96 |
Rock Stacker Join Date: Oct 2012 Location: Canberra, Australia
I mounted a 1.55 Growler on an Axial 1.9 beadlock to compare with my Rock Beasts on the same wheel. A PITA to mount! A bit smaller that the RB and too small for the Hammers IMO. RBs are just right and work really well. Sorry forgot to take a pic.
![]() | #97 |
| ![]() Yeah the rock beasts look pretty good......but I really like the tread pattern on the growlers. Scale wise I would say that the 1.55's at around 4 inches tall or the Baja Claws 4.19's would work out to be a 40 inch and 42 inch tire...... Right what most of the ultra4 rigs are running at KOH. I do feel the 1.55 look a tad small or maybe the sidewall looks weird because it's stretched..... but compared to the standard 1.9 Growlers which stand at 4.75 would make them 47's in 1/10 scale. Still not 100% if I'm gonna run the 1.55's or keep running the MT Baja Claws.
![]() | #98 |
![]() | #99 |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
Here's mine with the 1.9 Axial Ripsaws. They seem to work really well all around. ![]() |
![]() | #100 |
Ok so its been a while since I have posted anything..... summers been busy but there is a G6 coming up that I hope to attend and I wanted to change things up a bit. RPP had a sale awhile back so I picked up a Sand Scorcher body and a extra TH cage and decided to build up a Twin Scorcher. I have been working on grafting the body onto the modified cage. Still got a little more fender trimming to do and work out the body mounts. I am going for a Class 5 Unlimited Baja Bug look. ![]() ![]() Still trying to determine color, front bumper & lights. |
Yet Another Twin Hammers | Tin Soldier | Vaterra Twin Hammers | 12 | 02-19-2014 07:47 AM |
Savage00's Twinny Twin Twin Hammers | Savage00 | Vaterra Twin Hammers | 16 | 09-19-2013 08:09 PM |
Twin Hammers in Twin Cities? | 89XJ | Minnesota | 7 | 05-06-2013 02:59 PM |
