Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Gmade diaphragm shocks?
Old 03-19-2014, 03:50 PM   #1
Default Gmade diaphragm shocks?
Anyone using the Gmade diaphragm shocks? If so how do you like them? I am thinking about running the 85mm up front with my GCM mount.
OR would you recommend the aeration shocks? I am looking to stay away from the piggy backs if I can due to the fact that the piggy has to be run forward facing or it hits.
Beej is offline   Reply With Quote
Old 03-19-2014, 05:41 PM   #2
Pockets70's Avatar
Default Re: Gmade diaphragm shocks?
I'm running the 93mm's (internally limited) on mine and love them! No leaks so far. Just don't install the huge bumpstops that come with them. Use O-rings instead.
Pockets70 is offline   Reply With Quote
Old 03-19-2014, 10:24 PM   #3
I have the 85's on mine and they work great
indysand is offline   Reply With Quote
Old 03-20-2014, 11:37 AM   #4
I ordered the 85mm diaphragms. When you say use an O-ring, any specific O ring size wise?
Old 03-20-2014, 12:25 PM   #5
Pockets70's Avatar
anything with roughly a 3mm ID and 2mm thick should do the trick. Any internal shock O-rings will work as bumpstops outside.
Gmade diaphragm shocks? - Similar Threads
Gmade shocks Steve Hipsley Tamiya XC/CC01 1 08-17-2013 06:07 AM
Gmade diaphragm shock ? Manfjourde General Crawlers 4 06-04-2013 02:11 PM
XD Diaphragm Shock Unfadingpyro Axial SCX-10 6 03-17-2013 11:42 PM
Anyone using the Gmade TS-01 Shocks on R1 Flash Burns G-Made Crawlers 2 09-09-2011 04:12 PM
