07-17-2014, 03:29 AM | #1 |
Pebble Pounder Join Date: Sep 2009 Location: Heart of the Alps
| TH Over- or Underdrive
Is there a possibility to creat an Underdrive rear setup with a an other Vaterra ring pinion or an overdrive gear for the front centersection? An other possibility would be a SCX10 rear axle, but hows the gear ratio compared to the Vaterra rear? |
07-17-2014, 11:37 AM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
| Re: TH Over- or Underdrive
By underdrive or overdrive I'm assuming you mean a slightly taller or lower gear difference front to rear - I don't remember seeing R&P options for the TH but you may be able to achieve the same result by running tires with slightly different heights
TH Over- or Underdrive - Similar Threads | ||||
Underdrive for the R1... Finally | supermoturd | G-Made Crawlers | 55 | 01-05-2021 06:41 AM |
underdrive rear only | Airmicro | Axial AX-10 Scorpion | 10 | 01-01-2015 07:35 PM |
Over or underdrive? | Big Daddy | Axial SCX-10 | 15 | 12-09-2011 09:29 AM |
Underdrive pinion? | Tortuga275 | Axial AX-10 Scorpion | 3 | 11-11-2010 07:47 PM |
