Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Twin hammer shock build
Old 05-24-2015, 06:24 PM   #1
Default Twin hammer shock build
What is the correct way to fill the shocks on the twin hammers?
Is it filled from the top or the bottom??
The Bug is offline   Reply With Quote
Old 05-24-2015, 07:58 PM   #2
Default Re: Twin hammer shock build
From the bottom, put end cap on, turn it upside down and then fill, leave sit for a while.
grease up the cartridge, put the shock shaft through then insert shock shaft in the shock body all the way down and screw cartridge in while you hold the shaft down.
Chicken Man is offline   Reply With Quote
Old 05-25-2015, 04:55 AM   #3
Thanks
Twin hammer shock build - Similar Threads
Irie Products Twin Hammer ball bearing steering & upright shock tower Sr.Irie Chassis and Suspension 48 03-05-2018 11:14 AM
twin hammer shock fluid isac Vaterra Twin Hammers 2 04-12-2013 09:12 PM
