Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: is there a twin hammers electronics thread
Old 10-20-2015, 07:17 PM   #1
Default is there a twin hammers electronics thread
I tried searching, but my browser keeps flaking out and timing out.
Is there a thread that covers what you guys are running in your TH.
I'm thinking of getting one, and want to see what kind of budget I can get away with.
THanks guys :]
poomwah is offline   Reply With Quote
Old 10-20-2015, 07:42 PM   #2
Default Re: is there a twin hammers electronics thread
Depends if you want to go Brushed or Brushless. Im running. Motor: Rocket Racing 3100kv
ESC: Castle Sidewinder 3. Heres my thread on My Twin Hammers build.
W1ck3d0n3 is offline   Reply With Quote
Old 10-20-2015, 08:01 PM   #3
Thanks, my first instinct is brushless, just because that's what I'm used to, but I might want to get into some water, mud and snow, so I'm thinking brushed might be better
Old 10-20-2015, 08:03 PM   #4
The only thing thats not waterproof is my steerin servo.
Old 10-20-2015, 09:20 PM   #5
I picked up a 4000kv 4pole horizon combo for $84. Water proof and everything. Geared 22/78 it crawls pretty good and it is a blast in high gear.
lonleycreeper is offline   Reply With Quote
Old 10-20-2015, 09:22 PM   #6
was it this one 1/10 4-Pole 4000Kv ESC/Motor Combo | HorizonHobby
Old 10-20-2015, 09:25 PM   #7
I have one of these in my Yeti
Value Hobby R/C Hobby Store (Addison, Illinois): GForce 3650SL 4-Pole Sensorless Brushless Inrunner Motor-4300KV
I haven't run it yet
how about putting that in a Twin Hammers and getting a different motor for the Yeti?
Old 10-21-2015, 06:45 AM   #8
Originally Posted by poomwah View Post
Yes that is it. It is not a crawler system. But it does pretty good, where it really shines is power,there is plenty even on 2s.
Old 10-21-2015, 02:20 PM   #9
ok, went through the stash and found a gforce 3550 4 pole 4300kv. So that's what I'm going to use.
so, keeping the price as low as possible. How suitable would a castle sidewinder be?
Castle Creations | Sidewinder 3
Old 10-21-2015, 03:22 PM   #10
ok, hope I didn't screw up too badly, but, like I said, I'm going to run the 4 pole 4300kv
I ordered a Castle Creations Sidewinder 3 and CC Bec
an hs-5645mg for steering and an hs-225mg for shifting.
still have to pick batteries :P
Old 10-21-2015, 07:24 PM   #11
I am using the Hitec 5646, and 225 myself, no problems other. For crawling the steering could be a little stronger, but it works good for bashing. A bec is a good idea IMO.
Old 03-28-2016, 08:06 PM   #12
how has this setup worked ??
im trying to pick a setup myself,, sooo many options
luke_hammertime is offline   Reply With Quote
Old 03-28-2016, 09:50 PM   #13
CODYBOY's Avatar
I would look at the Holmes Hobbies BRXL speed control and a Expert 35 t motor, or a 13t brushless motor.
For servos you want something with a rating of at least 300 FPT. I run a Hitec 7954 for steering. The micro will work fine for a shifter if you set up the linkage right.
Hope that helps you out.
CODYBOY is offline   Reply With Quote
Old 03-29-2016, 09:04 PM   #14
sorry, but I assembled the kit, put it back in the box, and its been sitting ever since.
Old 03-31-2016, 05:44 PM   #15
Mines gonna be running a Tekin redline Gen 2 17.5t. We will see how it does.
fr8cture is offline   Reply With Quote
Old 04-02-2016, 12:40 PM   #16
I think I might through in my setup later. Cheap 4 pole sensored system, and cheap tower pro knockoff servos. We'll see what happens and if anything lasts haha. I have the knockoff hammers, want to keep the whole thing as cheap as possible. I imagine I'll end up paying for it.
I'm more worried about steering. Need to figure something else out with buying one of the kits. Stock steering is horrendous.
Sent from my LG-H901 using Tapatalk
amorton94 is offline   Reply With Quote
Old 08-09-2016, 01:30 PM   #17
Have you had a chance to run that setup yet. I'm running a U4 race this weekend, and I'm running a Tekin RS and a 17.5. what gearing did you run?
blarouche is offline   Reply With Quote
Old 08-09-2016, 02:02 PM   #18
I run a Tekin 17.5 gen 1 in my Twin hammers on both 2s and 3s geared anywhere from 24/82 for crawling, up to 27/82 for hauling. It seems happiest at either 24 or 25 tooth pinion. It's almost unbreakable on 2s, and I can easily break CVD's on 3s if I have a bad landing when on the throttle. Overall I'm very happy with the combo. It's got plenty of snap to leap up ledges and enough creep to move millimeter by millimeter.
meatmonkey is offline   Reply With Quote
Old 08-09-2016, 03:16 PM   #19
Thank you for the quick reply. I only run 3s lol, I will have to see if I can get one of my 5000mah 2s packs to fit in, I ordered the AMF battery tray to see if it will hold a bigger battery. Maybe I'// drop the pinion to like 20-22 and run 3s.
Old 08-11-2016, 02:37 PM   #20
Guys.. if I use this Nimh, will it work?
Currently I am on the small lipo batt.
Sent from my SM-N920C using Tapatalk
danvincent999 is offline   Reply With Quote
is there a twin hammers electronics thread - Similar Threads
New Twin Hammers and new electronics oneeye Vaterra Twin Hammers 10 02-20-2013 02:59 PM
