Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Completed kit, Sharing some pictures
Old 10-21-2015, 01:50 PM   #1
Default Completed kit, Sharing some pictures
Been a long time watcher of the twin hammers. Love the scale look....yeti just does not look as good. I finished the kit in a couple of nights after kids were asleep. Still deciding to go brushed or brushless. In the mean time, i made some aluminum panels, I think they turned out pretty good.
Attachment 328684
Attachment 328685
Attachment 328686
Attachment 328687
Sent from my Nexus 6 using Tapatalk
makanouchi is offline   Reply With Quote
Old 10-22-2015, 02:18 AM   #2
Default Re: Completed kit, Sharing some pictures
That camo looks awesome!!
Pau Hana is offline   Reply With Quote
Old 10-22-2015, 08:11 PM   #3
Good looking TH..
joe007 is offline   Reply With Quote
Old 10-22-2015, 08:23 PM   #4
Panels look fantastic. Once you go brushless, you don't go back. I suggest sensored for crawling, non sensored for budget.
lonleycreeper is offline   Reply With Quote
Old 10-22-2015, 10:32 PM   #5
Originally Posted by lonleycreeper View Post
once you go brushless, you don't go back.
x13
Sr.Irie is offline   Reply With Quote
Old 10-28-2015, 09:50 PM   #6
Camo is excellent! Is it water printing or vinyl or?
BrotherAndySLB is offline   Reply With Quote
Old 10-31-2015, 02:20 PM   #7
I work at a digital sign printing company. The design is printed directly to the .040 sheet of aluminum (like a street sign). Then cut with a jigsaw. I printed a 24x36 sheet and cut as I need it.
I put in a vxl setup I had laying around but that had no low end control. Ended up going with a mamba pro and a sensored tekin redline17.5t. The only thing I don't like is the battery placement, really kills the scale look. The price you pay for easy battery access I guess.
Old 10-31-2015, 06:57 PM   #8
I don't normally dig the new age digital camo, but it looks sick draped over your TH. You made the panels look so clean it could be stock.
If the visible battery really bothers you I've seen people shoe-horn 1800 2s packs under the interior ontop of the servo with a home-made battery tray. Then the ESC gets relocated between the shock towers. Makes battery changes interesting though.
I'm running a Tekin 17.5 gen1 on 2200mah 2s geared 25/82 for crawling, and 28/78 for snow-bashing or sandpit abuse. I think you'll like it much more than the velenion.
meatmonkey is offline   Reply With Quote
Old 10-31-2015, 07:27 PM   #9
That look really good, nicely done.
Leon Sidursky is offline   Reply With Quote
Old 11-02-2015, 08:09 AM   #10
Aluminum panels for the TH was easier that I expected, only one bend for the sides and one for the hood. My yeti XL was a lot tougher.
Makanouchi's kit build
Thanks for the tips for battery. I think I'll go with some sort of permanent, hidden battery mount and charge the battery while in the car. Then move the spare up towards the middle. I hate visible wires on the rig.
Old 11-02-2015, 06:53 PM   #11
Panels look great on both rigs.
nfcrockett is offline   Reply With Quote
Old 11-07-2015, 08:15 PM   #12
So here's my version of mounting the battery inside the body. I shortened the stock Velcro strap by folding it on itself and then sewed it together. Then clamped it to the chassis with plastic plate and screws. My 1300 3s maxamp fit like a glove. ESC relocated between the rear shock tower as suggested. 6 screws to replace the battery, I can live with that.
Sent from my Nexus 6P using Tapatalk
Old 11-07-2015, 08:24 PM   #13
I also hacked up the dear to clean up the lines a bit. Spare tire moved inward. I might have cut too much... Too late now.
Old 11-07-2015, 08:34 PM   #14
CODYBOY's Avatar
You should have pretty good exit with it like that.
CODYBOY is offline   Reply With Quote
Old 11-11-2015, 12:13 AM   #15
Added gear head Vegas wheels. Beautiful fit and finish.
Completed kit, Sharing some pictures - Similar Threads
[Video] Joe's SCX10 Kit Build Completed joerc2013 Axial SCX-10 8 03-04-2015 10:42 AM
Sharing some Inspiration 05Fronty4x 1.5 Scale Rigs 3 03-02-2013 04:31 PM
(Updated Pictures Tma Completed!!)? ColquittCustom405 2.2 Scale Rigs 381 05-12-2007 06:59 AM
