Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: My Twin Hammers
Old 02-09-2016, 02:56 PM   #21
Default Re: My Twin Hammers
Originally Posted by honchojoe View Post
What parts of the gears and which gears do you polish? I just picked up a metal gear set.
For me most of the friction was were the shift slider thing (do not know what to call it) slides on the square main shaft. I used rouge and coated the square shaft and inside the shift slider. Then moved it back and forth until the square shaft and inside of the shift slider was polished and moved buttery smooth. Then I also faced both sides of the drive cogs on the slider thing that index the gears and made sure the drive cogs were at 90 degrees then polished. Then the notch where the shift fork runs and all parts of the shift fork where they are in contact with each other. As for the gears themselves I just cleaned up where the cogs index and drive, not a hole lot there. Over all just look at the parts and fit them together outside the trans. Pay attention to contact points, look for casting marks that my be a problem. I am sure not all of them are exact, it is manufacturing.
Sr.Irie is offline   Reply With Quote
Old 02-10-2016, 12:39 AM   #22
Thanks for the help works like butter now!
Lochrie2 is offline   Reply With Quote
My Twin Hammers - Similar Threads
Twin Hammers cage on SCX chassis bouncer conversion aka Bounce Hammers! mce076 1.9 Scale Rigs 36 07-25-2015 03:16 AM
My Twin...Twin Hammers build start sanny632 Vaterra Twin Hammers 8 03-09-2014 01:01 PM
Savage00's Twinny Twin Twin Hammers Savage00 Vaterra Twin Hammers 16 09-19-2013 09:09 PM
twin hammers zim35 Scale Comp Rules 264 05-19-2013 10:54 PM
Twin Hammers in Twin Cities? 89XJ Minnesota 7 05-06-2013 03:59 PM
