Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: How to remove rear shock?
Old 02-05-2016, 10:56 AM   #1
Default How to remove rear shock?
Noob question: How do I remove the rear shock from its lower mounting position? I have removed the screw that goes thru but the shock won't budge.
drabina is offline   Reply With Quote
Old 02-05-2016, 11:01 AM   #2
Default Re: How to remove rear shock?
Probably need to pull harder? Seriously.
Sent from my XT1096 using Tapatalk
Ca. Off Roader is offline   Reply With Quote
Old 02-05-2016, 11:03 AM   #3
All you need is the right amount of force. Use a flat screwdriver and bend carefully upwards.
Skickas från min iPhone via Tapatalk
Ronken is offline   Reply With Quote
Old 02-05-2016, 11:11 AM   #4
Come on junior...use some muscle...like Ronken said, use a small flat head and pry that bitch out.
VTHDAN4467 is offline   Reply With Quote
Old 02-05-2016, 11:19 AM   #5
Thanks. I thought that it should just pop right out but wanted to be sure. Will try again with more force when I get back from work.
Old 02-05-2016, 11:21 AM   #6
Just doing some service on the shocks or ?
Old 02-05-2016, 12:07 PM   #7
Maintenance. Front shocks look like have no oil so while rebuilding I thought of checking the rear ones as well.
Old 02-05-2016, 12:51 PM   #8
Smart move my friend, just did a full rebuild/check on my rear shocks the other week.
Old 02-05-2016, 07:21 PM   #9
So did they finally come out?
Old 02-05-2016, 09:00 PM   #10
Yes. The first one was stuck pretty good. The other one came off easily. They are all cleaned and refilled with new oil now.
Old 02-05-2016, 09:54 PM   #11
Tools needed:
A good strong string
Step ladder
Broom stick
Naked pictures of Bea Arthur
Flat tip screw driver
Acme anvil
Trailing arm/stuck shock
Instructions:
Set up the step ladder, position the anvil atop the broom stick and atop the ladder. Then tie the string to the broom stick. Stand back and give the string a good tug. If positioned right the anvil should fall. Now mark the spot on the floor, if the anvil has not done it for you. Now set the anvil back atop the broom stick atop the ladder as you did before. Now position the trailing arm with the stuck shock on your mark with the flat tip driver in the pocket of the trailing arm, under the shock end. Back up pull the string and Whaaa Laa
Sr.Irie is offline   Reply With Quote
How to remove rear shock? - Similar Threads
Easier way to remove rear body pins on Honcho? jeff22 Axial SCX-10 16 02-02-2015 04:12 PM
how to remove the rear axle? dirtslow Axial Wraith 2 09-26-2012 08:31 AM
Rear Shock Mounts? Grumpster1980 Tamiya XC/CC01 26 02-20-2010 12:25 AM
word to the wise remove spring before changing shock oil slobin3d Chit Chat 1 10-12-2006 11:38 PM
