Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Just, ordered a kit! (Dstacks hammer's)
Old 02-06-2016, 10:47 AM   #1
Like the title states I just got my kit for $225 at Amain. Very excited about this and just want some tips or advice on it.
My setup
120a sensored esc
Trinity 13.5t Duo 1
2600mah Turnigy super shorty 90c lipo
Hobbyking servos.
Just need the truck to come everything else is waiting. Will update
The only upgrade I ordered off that bat is a aluminum top plate for $12. Aluminum aircraft grade made in the U.S. Other then that I was thinking about a T-bone bumper but not sure
dstaks is offline   Reply With Quote
Old 02-06-2016, 05:26 PM   #2
Default Re: Just, ordered a kit! (Dstacks hammer's)
Only thing I saw is you don't have a pinion for your motor.
lonleycreeper is offline   Reply With Quote
Old 02-06-2016, 09:09 PM   #3
I run a trinity gen2 13.5 sensored with a 26 pinion and it seems like a good compromise between speed and crawling
Lochrie2 is offline   Reply With Quote
Old 02-06-2016, 10:28 PM   #4
Does the kit not come with a pinion? What pitch?
Hmm, so if I'm not really goin to crawl much should I go higher?
Old 02-07-2016, 07:32 AM   #5
A 48p pinion and with that much power you will probably need this too. Robinson Racing Twin Hammers 78 Teeth Blackened Hardened Steel Spur
Old 02-07-2016, 02:22 PM   #6
So I ordered a 26t pinion and a program card for my esc. Last order for awhile. Would like some lights but I'll wait
Expensive for me , I'll try the stock spur for now.
The gear
Tranny done, locked in high gear. So far my only complaint is screw quality. Stripped a 3x25mm in the tranny case and I still have to get it out :/
Stripped a set screw in the tranny drive cup. Pretty pissed ugh
Old 02-13-2016, 11:07 PM   #7
That sucks man.. got to remember as you screw in the first time they get quite hot so go slow
Spunkybob is offline   Reply With Quote
Old 02-14-2016, 02:57 PM   #8
Well I picked up new hex drivers and drilled out the screw on the cup. Hopefully I can get it to work
Fixed it and now on a role!
Old 02-15-2016, 09:03 PM   #9
Looking good.
Why do you mount everything so far forward? You might have issue mounting the front suspension with the wires there (Or have you got upright front shocks?)
Old 02-16-2016, 10:09 AM   #10
im contemplating wether to go upright on the shocks.
Just, ordered a kit! (Dstacks hammer's) - Similar Threads
Just ordered my kit! Fatman489 Vaterra Ascender 0 12-12-2014 07:09 PM
Kit Ordered, Parts Ordered, Suggestions??? OkinawaCrawler Tamiya XC/CC01 6 02-21-2014 10:52 AM
Just ordered Wraith kit! AG74683 Axial Wraith 36 11-20-2013 10:25 PM
Just ordered a Wraith kit highwaystar Axial Wraith 4 12-07-2012 02:21 PM
Just Ordered My Kit... BoardN88 Axial XR10 2 03-31-2012 09:48 AM
