07-12-2016, 04:31 PM | #61 |
Quarry Creeper Join Date: Feb 2016 Location: Australia
| Re: Always Upside down
Freaking hell that's amazing!!! Sent from my SM-N910G using Tapatalk |
07-12-2016, 04:36 PM | #62 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
| Re: Always Upside down Quote: Sent from my SM-G920T using Tapatalk |
07-12-2016, 08:20 PM | #63 |
I don't suppose you could send the plans (for a fee) so I could get it printed locally in Australia? Feel free to sue me if I tried to sell it as my own. Sent from my SM-N910G using Tapatalk |
07-13-2016, 01:41 PM | #64 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
The max width is defined by the shock towers = 40mm The version i've done including the tx box then has a max length of 46mm. The plain version does not limit the length. I could probably do a custom length version for you if needed, but you still have limited width. | |
07-13-2016, 01:47 PM | #65 | |
The price of the Shapeways build is by far the bulk of the cost, but their prints are really good. I send parts like this to Aus though eBay from time to time and the shipping is not that bad really. | |
07-13-2016, 04:43 PM | #66 | |
Sent from my SM-N910G using Tapatalk | |
07-16-2016, 06:16 AM | #67 | |
07-16-2016, 07:02 AM | #68 |
| Re: Always Upside down |
07-25-2016, 03:58 PM | #69 |
Wow, very impressive work on the front structure you've designed! Maybe I'm just weird, but I prefer the handling of my Twin Hammers with 60-70 weight in the stock rear shocks. I figured the trailing arms reduced the leverage ratio so I needed to up the damping. I think that the manual even calls for 60-70 weight depending on setup. For the rear swaybar "slack", I put HPI 5x9x2 O-rings on the front of the trailing arms pivots at the chassis, figuring I wanted to keep the arms true with the shocks instead of the rear axle. I also swapped the lower swaybar link end for a conventional 1942 traxxas rod end with a longer bolt and nylock nut. This reduces the offset leverage from the swaybar onto the arm since it moves the pivot closer to the centerline of the trailing arms. |
07-26-2016, 02:40 AM | #70 |
I wouldn't disagree with your feelings on weight distribution. I certainly didn't want to make it front heavy, but could not live with the high centre of mass. This solution works really well. I'm running the front end sat a little low which also helps, and it turns really well now on most surfaces without ending up on the roof. I think appart from the hopeless sliding rack steering of the stock TH, i've been really impressed with the vaterra. Now, after building and running an axial wraith, i know just how good the vaterra is. The wraith has cost me a fortune to keep running and breaks something at almost every outing. The handling sucks too, i think due to the lack of ackerman steering. I've upped the battery to 3s to help shift it's bigger weight, but that's helping to break more stuff too. For no fuss bang for buck, the kit TH is clearly very hard to beat! |
08-15-2016, 07:21 AM | #71 |
Newbie Join Date: Nov 2015 Location: Albany
I'm suckered in. Ordered the whole lot from Shapeways and looking forward to the install. Part of the appeal is the clean finished appearance to your design. Makes the original layout look more awkward than it already was. I never did like the receiver hangout out in the open with no dedicated space either. I had my own home grown upright shock mount and love it but yours just looks better plus integrated with bell cranks. Brilliant!
08-17-2016, 07:43 PM | #72 |
So my first pieces from Dbx came in! This package was the shifter assembly. Very nice finish and much stronger than I was anticipating. I love the design, kudos to you sir. But I have some fitment issues. The black base seems to be about 3mm too short? I placed the alignment nubs that are on the bottom of the base piece into the holes of the trans from each end to make sure. The screw holes on my trans are 42mm center to center. Im wondering if its becsuse I have the China Hammer...which shouldnt matter as I have upgraded this thing with alot of after market Vaterra parts and have had no issues. Update: I ordered an actual vaterra trans case. The china hammers came with weird 5 wire servos so im thinking the mouniung tab is different. Especially after looking at transmission cases of other vaterra hammers online. Sent from my SM-G900V using Tapatalk Last edited by eMoon; 09-22-2016 at 08:54 AM. |
08-17-2016, 11:38 PM | #73 |
Errrr... Yeah, that is strange! Mine are 39mm between centres. Quite a few of these have gone out without issue now. Your front ear appears to be longer than most. Grrrr. Just to be clear, is that the china hammers case or replacement vaterra case that is 42mm? I will do a 42mm version for you. PM me to cofirm its exactly 42mm and we'll sort something out. Yes, the 'stront and flexibe' is impressively robust! |
08-18-2016, 06:06 AM | #74 |
Thanks Dbx. This is currently the China Hammers transmission case. Knowing your measurements, I think that's where the hiccup is since we are 3mm different, exactly what I thought it was. No need to print a new one for me as I wanted to replace my trans case anyway as a couple screws are stripped and it won't pull tightly closed. I've ordered a Vaterra case to confirm size differences and swap it out. I will take better measurements for you and post them here in case you decide there is a need to have a version for clone hammers. Otherwise I'd leave it alone, it's a really nice piece. After all, a replacement trans case is only $5. It is weird though as everything else, minus a pinion bearing on the rear axle, has been the same to the true Vaterra. |
08-18-2016, 03:09 PM | #75 |
Newbie Join Date: Mar 2014 Location: United States of America
Hopefully the steering pieces work Sent from my SM-N900V using Tapatalk |
08-18-2016, 04:49 PM | #76 |
08-18-2016, 05:42 PM | #77 |
I have no doubts about things working and didn't mean for this to cause any. Just trying to let folks know what to watch out for if they have a China Hammer. Just get a $5 vaterra trans case and I bet things are gravy. I'm sure the steering parts will align nicely as I've already installed Sr Irie's bell crank on one of them as seen above. Sent from my SM-G900V using Tapatalk |
08-18-2016, 05:50 PM | #78 |
I wasn't meaning to cause any alarm either, when you buy a clone you have to deal with any consequences. I am looking forward to ordering the steering and battery tray. Sent from my SM-N900V using Tapatalk |
08-18-2016, 07:21 PM | #79 |
Hey Dbx, I confirmed the China Hammers hole to hole distance on the transmission case is 42mm center to center. Looks like the alignment hole to screw hole is ok. Must have been a design change on the China version because of the servos tbey use. Vaterra trans case came in. The shapeways base plate fits like a glove. Can't wait to change out the case. Sent from my SM-G900V using Tapatalk Last edited by eMoon; 09-22-2016 at 08:54 AM. |
09-05-2016, 11:05 AM | #80 |
Rock Stacker Join Date: Feb 2013 Location: Denmark
Bought "scorched_parts" Twin Hammers Steering and Suspension Upgrade, because liked how the servo was located, but think that there is a small flaw in the design. The corner of the servo and part of the Steering and Suspension Upgrade protrude outside the body panels. Will be sad to cut my body panels (Carter Fab body panels) because they keep mud, etc. out. |
Always Upside down - Similar Threads | ||||
Upside down shocks? | brilamb2 | Axial AX-10 Scorpion | 18 | 10-08-2009 02:08 PM |
Upside down shocks ? | SMUDGEBUG | Axial AX-10 Scorpion | 21 | 12-05-2007 03:38 PM |
upside down shocks? | mysharona | Newbie General | 3 | 11-27-2007 03:43 PM |
Upside down shocks | pbfrk4life | General Crawlers | 9 | 04-17-2007 11:53 AM |
Axles upside-down? | smojoe | Tamiya TLT Crawlers | 1 | 04-18-2006 06:22 PM |
