09-05-2016, 01:16 PM | #81 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Always Upside down Quote:
From what i can see, the carter fab panels are quite unusual in that they tuck in much further than the stock. The stock body, and any body that doesn't come in like that will fit fine. Looks like a little bit of trimming will be required! Sorry Dude. It's hard to design a perfect fit for stock parts, but impossible to design for all the combinations of accessory parts people may fit. Once you get it all together, you won't be disappointed. | |
09-23-2016, 08:16 AM | #82 |
Newbie Join Date: Nov 2015 Location: Albany
Hi Dbx, I'm looking for a new shorty pack as I think my current battery is puffed and I don't care to chance using it much longer. It was also just a tad too long for your battery holder. Can you share what pack you are using or the dimensions you designed it for? Thanks. |
09-23-2016, 09:08 AM | #83 | |
My latest trays are 96mm, which allows some other batteries, but you can always trim the end to fit these too. | |
09-23-2016, 11:34 AM | #84 |
Copy that. I also found you did put recommended battery dimensions on the Shapeways page. Sorry about not doing research before asking... Other than that I have all the pieces installed on my TH Bug and report no issues other than the ESC holder hitting the upper links on full compression, but that's only becuase of my rear shock choice. With 110mm kings it will bump but when switched to Gmade 103mm they just kiss each other. Wound up being perfect. My other issue is to somehow fix some binding that occurs in my trans when shifting from high to low or vice versa. I have to rock the car a bit to get the gears to engage but no issues to report with the Scorched Parts. |
09-23-2016, 12:22 PM | #85 | |
09-24-2016, 10:15 AM | #86 | |
Rock Stacker Join Date: Feb 2013 Location: Denmark
I got it all to fit. There were just a little bending and sawing To show what I mean by that it goes beyond the chassis, I have taken a few pictures where I have put duct tape on, to show it. Hope that you can see what I mean? | |
09-25-2016, 11:14 AM | #87 |
Hey dbuus, I'm pleased you have it all fitting now. That corner is the furthest out point, but does fit within the stock body, and the majority of others. Hopefully you will now feel the benefits! |
09-26-2016, 09:48 AM | #88 |
| Re: Always Upside down Have not had a chance/time to test it yet (work occupies too much of my spare time ), but am looking forward to get it tested.
09-26-2016, 11:25 AM | #89 |
As mentioned before I have all the Scorched Parts stuff installed and was just able to fire up the Twin Hammers with it. I am reusing the same Blue Bird steering servo I was before and I feel the power of the servo is utilized much more effectively. I was already using another bellcrank type set up too, but now it turns with much more authority and strength. I feel there is a greater degree of steering angle provided with the Scorched Parts steering kit too. Upon close inspection, I noticed slight distortion on the chassis at full steering lock both left and right as the servo tried to turn the wheels in the stock location. There was no binding and I wasn't bumping up against physical travel limits of the knuckles but the servo just couldn't push the bellcrank to full lock. I just think the Scorched Parts mechanics allow the servo to apply full force better than the stock location. |
11-04-2016, 03:11 PM | #90 |
RCC Addict Join Date: Mar 2011 Location: easton
Do you know if you can run your battery tray with your cantilever steering set up? Sorry if this was already mentioned, and I didn't see it on shapeways Sent from my iPhone using Tapatalk |
11-05-2016, 04:48 PM | #91 | |
The 'Steering and Suspension' kit is the full mod, designed to work with the low slung battery tray. The 'Bell Crank Steering' kit just addressees the steering upgrade, and so will not work with the low battery. Hope that helps! Db | |
12-05-2016, 01:56 PM | #92 |
A bit of Autumn / Winter fun with the Scorched Parts Hammers. http://vid1074.photobucket.com/album...pshcmwrszm.mp4 Last edited by Dbx; 12-05-2016 at 02:00 PM. |
12-21-2016, 04:29 AM | #93 |
| 20% off at Shapeways!
Just letting you guys know, Shapeways are currently offering a 20% discount!
05-26-2017, 01:41 PM | #94 |
Update on the Scorched Parts bell crank setups and other parts. I have now updated the kits on Shapeways. The kits are now simpler to buy and by combining parts in the prints, they are cheaper too! Check the link at the bottom of my post. The bell cranks kits have been a steady seller for the last six months and i've had nothing but good feedback. All feed back gratefully recieved. As stated in my shapeways shop, if theres a problem, tell me (i'll fix it), if you love the kit, tell others! |
05-26-2017, 01:52 PM | #95 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Finally got to another Twin Hammers build. His one has your shock mount/bell crank system in it. I will put up a couple of pics later today when I get a chance. Bottom line is performs well. Haven't beat it hard or anything to test for extreme durability, but that isn't really my driving style anyway. For anyone looking a front suspension/steering upgrade combo. I would not hesitate to go in this direction. The design is sound and the parts quality equally so. Thanks again Dbx. |
05-26-2017, 05:47 PM | #96 |
Thanks for that Smog! Always great to hear from a happy TH driver!
Always Upside down - Similar Threads | ||||
Upside down shocks? | brilamb2 | Axial AX-10 Scorpion | 18 | 10-08-2009 02:08 PM |
Upside down shocks ? | SMUDGEBUG | Axial AX-10 Scorpion | 21 | 12-05-2007 03:38 PM |
upside down shocks? | mysharona | Newbie General | 3 | 11-27-2007 03:43 PM |
Upside down shocks | pbfrk4life | General Crawlers | 9 | 04-17-2007 11:53 AM |
Axles upside-down? | smojoe | Tamiya TLT Crawlers | 1 | 04-18-2006 06:22 PM |
