11-20-2016, 02:15 AM | #1 |
Newbie Join Date: Nov 2016 Location: Singapore
| Front Diff to use as Rear Open Diff
Hi, I haven't own a Twin Hammer yet and looking at getting one. I like to check if the Front Diff is compatible with the Rear as I am looking at running a "Open" Diff. I just happen to see that the Rear Diff Locker is a different Part Number form the Front Diff. Please advise. |
11-20-2016, 12:05 PM | #2 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
| Re: Front Diff to use as Rear Open Diff
The axle shafts have to be drilled for the cross pin in the spider gears inside the diff, other than that a diff from the front should work in the rear.
11-20-2016, 09:07 PM | #3 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
The rear axles also need a bit of length removed or the center pin will not fit in the carrier.
11-21-2016, 03:31 AM | #4 |
That sounds like some precision drilling and cutting required.
11-21-2016, 11:43 AM | #5 |
| Re: Front Diff to use as Rear Open Diff The hole for the center pin does need to be in the proper location and square for the side gears to work right. But it is something that can be done relatively easy with the right tools, I would say a drill press at the very least.
03-02-2017, 12:54 PM | #6 | |
| Re: Front Diff to use as Rear Open Diff Quote:
Good info, maybe a "kit" is needed? | |
Front Diff to use as Rear Open Diff - Similar Threads | ||||
Open rear diff??? | Tgreer | Vaterra Twin Hammers | 13 | 06-23-2020 05:57 PM |
Open rear diff | Lochrie2 | Vaterra Twin Hammers | 3 | 02-11-2016 08:26 PM |
Open front diff | Tgates | Axial Wraith | 16 | 02-05-2014 07:14 PM |
Open Diff at front | CarLo | Axial SCX-10 | 3 | 12-06-2009 07:25 PM |
Open front diff | BeeRC | General Crawlers | 3 | 06-05-2008 06:21 PM |
