Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Open front diff that is not open
Old 02-16-2017, 06:49 PM   #1
Default Open front diff that is not open
My front diff is locked with the spider gears installed...
So okay I got my the kit... and started building it... I'm pretty rc savvy and have built quite a few...
Here is my issue..
I have taken this thing apart twice with the same issue... with the spider gears in my diff and 500k oil (the first time) and just 35wt shock oil the second time...
The drive cups will spin as they should... but when turning the pinion gear you can't stop either wheel...
Both drive cups spin super smooth install it into the case housing install the shaft onto the pinion and test it out... complete locker...
So not what I want...
Not tellin is offline   Reply With Quote
Old 02-16-2017, 07:55 PM   #2
Default Re: Open front diff that is not open
Do not know if this is it of course but,,,,I had a used one I purchased. I found the two flat spots on the cross shafts that the spider gears run on were not lined up. Which bound the spiders up and made it like a locker.
Sr.Irie is offline   Reply With Quote
Old 02-17-2017, 12:45 AM   #3
It is possible... I'm going to get it back apart here soon and double check it as well as the gears...
Old 02-17-2017, 12:00 PM   #4
I went ahead and ordered a whole new diff set up... something is wrong inside of this one...
On a good note... when my integy parts come in I will be able to build the whole unit and swap it all out without having to take the stock unit apart...
Ordered the whole aluminum set up for the front end...
Old 02-17-2017, 04:34 PM   #5
Found the issue if anyone else happens to have the same problem...
One of the spider gears did not fit onto the cross shaft... it would slide on one side but not the other...
Jewlers file clean up the offending gear and good as new..
Open front diff that is not open - Similar Threads
Front Diff to use as Rear Open Diff ongbenghui Vaterra Twin Hammers 5 03-02-2017 12:54 PM
Scx10 Open Front Diff? BigChevyTruckin 1.9 Scale Rigs 42 05-14-2015 01:03 AM
Open front diff Tgates Axial Wraith 16 02-05-2014 07:14 PM
Open Diff at front CarLo Axial SCX-10 3 12-06-2009 07:25 PM
Open front diff BeeRC General Crawlers 3 06-05-2008 06:21 PM
