Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: TH build - battery question?
Old 07-11-2019, 07:58 AM   #1
Default TH build - battery question?
I am in the process of building my TH with a GCM plate and shock tower. I completely gutted the electronics and replaced with 3S capable esc and motor. I use ProTeks 4100mah lipo in all of my other crawlers and thought for sure this would be s good fit with the GCM plate. Well now that it is assembled I find that this battery doesnt allow the hood to close without distorting it really bad. Does anyone have any suggestions for a 3S battery that fits well but has a decent mah capacity? I have some 3S 1500mah 50C lip is but I am concerned about run time being way too short with that low of a capacity. Thanks!
Var1000 is offline   Reply With Quote
Old 07-12-2019, 06:38 PM   #2
Default Re: TH build - battery question?
The 1500's should last about a half hour if your crawling. Plus they are light.
Otherwise I can't help much as I run 2200 3s in the stock tray.
meatmonkey is offline   Reply With Quote
TH build - battery question? - Similar Threads
Battery Question crawler619 Axial Wraith 6 03-13-2014 02:31 AM
battery / battery charger question EricTheRitt Electronics 4 09-07-2011 07:59 AM
Battery question...yes, I read the battery thread...twice... MikeTJ Losi Micro-Rock Crawler 14 06-07-2011 07:44 PM
Battery question Crazyrctoon89 Newbie General 4 02-05-2011 10:35 AM
